Question about Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
I have a Maytag washer, MAV6200AWW, on more than one occasion it has not completed a cycle.
It was do to imbalance.
Is it the timer?
  • 1 more comment
  • tribute06 Feb 26, 2008
    The first time she said there was water in the tub.
    not the next time.
  • tribute06 Feb 27, 2008
    My wife experienced a glitch that caused the machine to not complete a cycle.
    A. Whites cycle: timer had moved to the off position with water still in the tub, she selected another cycle and the machine ran all the way thru the cycle.
    B. Gentle cycle: the machine agitated for a few seconds then stopped, again she reset and the machine completed a the gentle cycle.
    I am leaning toward the timer as the problem, what am i not lokking at? Maytag Atlantis CIRCA 2000.
  • Anonymous Mar 19, 2014
    coin operated washer maytag does not complete the full cycle
Most people over look a timer problem
Posted on Aug 19, 2008
My maytag atlantis washing machine sometimes fills and fills with water to start a cycle, but drains at the same time. This means it never senses the water level as full enough to begin, so it just fills and fills for hours on end. It's like the sensor for how full the load is is broken, or something. Any similar problems? Know how to fix it?
Posted on Mar 10, 2008
When would the washer stop?
Is there water in the washer when it stops?
Posted on Feb 26, 2008
  • goodshepherd Feb 27, 2008
    Then its could be the drain pump.
    The machine pumps water for certain amount of time. In that time if the water does not get pumped then it will not go properly into the next stage of cycle (rinse, dry).
    Check to see if something is blocking the drain pump.
    (I have noticed pieces of clothing like socks could somehow get in there, don't know how)
    open the front and check the pump. The drain water should be quite forceful when its getting pumped. move the switch the rinse and check.
My maytag mav6200aww washer stops at the rinse or the spin cycle. However, if I wait about 30 min it will work. Possibly a bad timer? Are they difficult to replace?
If the washer is working properly in the wash cycle & not the rinse or spin cycle, I would suspect a defective timer especially with the delay of 30 mins you described. Replace the timer with this part.
Jan 14, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Water Level and Water continues to drip after cycle has ended.
The water dripping into the tub is caused by the fill valve solenoid not closing completely. The fix is to replace the fill valve. The overfilling of the washer is caused by the pressure switch. Over time the diaphram within the pressure switch becomes fatiqued & fails. The fix for this is to replace it as well... Hope this helps... Bill
May 18, 2009 | Maytag MER5775Q Electric Kitchen Range
Maytag mav6200aww washing machine doesn't rinse clothes
If you say this only happens on the Colors and Whites cycle i dont see what the lid switch or balance sensor (if your washer has one) would have to do with it. It does seem like it has something to do with the timer,,, it really sounds like maybe the (Colors & Whites) section of the timer is malfunctioning. Inside the timer, there are a series of gears and switches, and by slamming the lid, or tapping on the timer control knob,,, it could maybe help the damaged part of the gear move, temporarily "fixing" the problem
Mar 13, 2009 | Maytag MAV6200 Top Load Washer
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
365 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
