Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Kenmore side by side
I bought a used fridge, and I can't get the water dispenser to work or the
ice dispenser. The ice maker is working, but it's not droping the ice?
    President:
  • Frigidaire Master
  • 2,651 Answers
Check wiring leading through the top of freezer door hinge. might not be plugged in
Posted on Mar 04, 2008
HAVE A KENMORE FRIDGE M.#106.74253400 WATER DESPENSOR STOPPED WORKING AN CAN HEAR IT HUMMING AN ALSO THE ICE MAKER WORKS SO I NO ITS GETTING WATER? THANKS
my kenmore did the same thing, It had a duel water solenoid on it and one that let water into the door water dispenser went bad. also my ice cube started to get smaller, the rubber in the other side of the water solenoid was dry rotting and eventually ruined the ice maker. I replaced the duel solenoid and ice maker and had no more problems.The solenoid is on the back of the fridge, it is what the main water supply connects to.
Dec 31, 2011 | Refrigerators
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
Water is not coming out of the water dispenser. The ice dispenser is working though. I see this question posted alot, so must be a common problem, but I don't see any answers. I have a Kenmore side...
For water not dispensing problem:----------
There possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the water dispenser. If this tube is blocked then water will not flow, when you depress the water dispenser paddle. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve .This water valve is for letting the water. The main water valve the back of the fridge section. This main valve lets the water enter the refrigerator.This water valve is a twin valve.This valve has two tubes in it.One for water dispenser and one for ice maker chamber.The one side of valve is working, but other side of the valve is not working.The valve is got stuck in one position, so ice maker side is working, but water dispenser side is not working.--------
The valve is not a costly part and can be easily replaced.-----------------
then You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Sep 06, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
May 29, 2011 | Kenmore Refrigerators
Kenmore Side by Side not making ice
This problem is most likely the water control valve on rear of refrigerator. If your ice maker is empty pour tap water inside it and let it freeze. If it dumps the ice then the water control valve. If nothing happens the the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice Maker not working
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 17, 2009 | Kenmore 57029 Side by Side Refrigerator
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Side by Side Fridge - Ice maker/water dispenser
we got to chat about this so hold my rating till we are don how is your water hooked up house valve or self pericing saddle valve what kind of pipes do you have when you push the door dispensor do you hear any sound have you checked your filter
Mar 31, 2008 | Refrigerators
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
91 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
