Question about LG RD-JT40 Multimedia Projector
RD-JT40 powers on but nothing shows
My projector suddenly went dead while i was using it with no warning of the bulb needing replacing or that it was too hot. The projector now makes a clicking noise for a few seconds when it is turned on and after a few more seconds the projector turns off with the bulb wanrning light permanently on. I assume I need a new bulb but I am concerned that even with a new bulb the same problem will occurr. any ideas??
  • rassklass Feb 26, 2008
    it looks clean, i cant really tell though. definately connected properly cuz the screws are completely fastened, unsure about the fans as i cant get into the projector, ill have another try though. will it do it serious damage if i turn it on without a bulb in??
    Problem Solver:
  • 9 Answers
On the plate you have removed to remove the lamp there is a pin. So refit the plate("doar") and the noise will be gone. There should not be any damage to the projector (I did the same this moring with no bad effect to the projector)
Posted on Jul 04, 2008
  • 27 Answers
Check the lamp,
does it look clean inside
is it fully home on the connecting pins
are the lamp door and fan switches made correctly
Posted on Feb 26, 2008
Projector suddenly went unresponsive
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
Jan 18, 2013 | Panasonic PT-AE700U Multimedia Projector
Lamp reset LG RD-JT40
Try to do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
Good Luck.
Jan 26, 2008 | LG RD-JT40 Multimedia Projector
NEC vt470 projector suddenly not turning on
I'm with Greg on this, I've had both of those problems individually on different VT4xx's (having both a number of them and a working knowledge of screwdrivers, figured out what was up by process of elimination). Sometimes bulbs die early - if it's really early you might want to see if there was any warranty period remaining on it - and the power boards in these projectors do sometimes break down. They were built in an at-risk period for having troublesome power capacitors installed into them, for starters...
If you are e.g. at a school which has several of these projectors issued to individual teachers, organise to swap the bulbs over between both your units and see which, if either of them, still work afterwards. If theirs was originally working, and after the swap, both are dead, you've got a dead bulb AND something else wrong with the projector, POSSIBLY but not necessarily that PCB. If yours then works but theirs doesn't, it's the bulb. And if there's no change, then both bulbs are good but your projector is toast.
And if it turns out that it's a projector fault, unless either you or an in-house tech can investigate and do the fix either for free or very cheaply, it's probably not worth getting it repaired. These models are really quite old and under-spec these days, and you can replace the entire thing with a brand new model of similar specification - with a working bulb installed! - than it would cost you to buy a single replacement bulb for the NEC.
Nov 08, 2012 | NEC VT470 Multimedia Projector
No power
there are six screws in the base and two in the back of the unit. After taking off the top I saw a red button on the front that was a little pushed out - I pushed it in and I got the led lights back :)
Jun 22, 2009 | Sharp XR-10X Multimedia Projector
Infocus LP530 no power
the power supply needs replacing. sometimes the caps are dried up, but show no signs of damage. when the caps doesn't work, the ps doesn't work.
May 07, 2009 | InFocus LP 530 Multimedia Projector
Projector suddenly shut down
you need to reset the lamp timer. turn it on, and press and hold the left arrow, right arrow, and power button until it resets.
Dec 17, 2008 | Mitsubishi ES100U Multimedia Projector
Resetting lamp on a lg rd jt40 projector
remove bulb. replace bulb. within ten minutes press exit on projector and hold for three secs. then immediately press menu then press left or right arrow button. you are done. turn off then turn on
Jul 04, 2008 | LG RD-JT40 Multimedia Projector
Projector Doesn't Power-ON
Hi bmosai
Yes you will have to replace the lamp.
The Projector will shut down and stay off as a safety feature.
May 04, 2008 | Panasonic PT L711U Multimedia Projector
Hp VP121 needs new bulb?
Hi there
Take out the lamp and check for any marks on the inside ( shaft ) of the lamp. If there is marks or discolouration on it then you can be 100% sure it is the lamp.
Apr 10, 2008 | HP VP6121 Multimedia Projector
Help me Please
I have just reset my lamp! Disconnect all cables but the power, switch on it will search for a source, the lamp timer message will display press exit untill it will give you a message to press menu to reset the lamp timer, it will give you a option to press left or right to reset. I used the buttons on the projector not the remote.
Jan 31, 2008 | LG RD-JT40 Multimedia Projector
254 people viewed this question
Top LG Office Equipment & Supplies Experts
Jaime Hernandez
J.D. Browning
J.D. Browning
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
