Question about Dell Inspiron 1100 Notebook
I need help with power problem
The power on my laptop goes off and on constantly. When no power is going through the laptop the screen gets a little dark and it lights back up when there is power. The AC adapter is fine. This has been going on for months now. Also, the light on front of the laptop the third light it blinks orange about 5 times then it blinks green once. This also has been going on for a long time now. Is there a solution to this because my pc cuts off a few minutes later when there's no power going through. I think it's the power socket on the back of the laptop where you plug in the AC adapter. I think it's loose or something because I can sort of move it while the plug is in.
    President:
  • 778 Answers
You are correct about the DC plug on the 1100, they are well known for the problem you posted. It could be one of two things, the solder points where the DC jack is soldered to the motherboard could have "cold solder joints" and re flowing the solder will fix it. Or the DC jack itself is faulty (the more common issue with these Inspirons) in which case almost all PC service shops will insist that the Mother Board has to be replaced (Not worth replacing), but you can obtain the jack for a reasonable fee and either replace it yourself (if you are very good at desodering and soldering, It's surface mounted, and not through hole which through hole is a lot easier to do), or open the laptop remove the Mother Board and take it in to a reputable electronics shop and have them use their state of the art equipment to replace the faulty jack for a reasonable fee.
Good luck.
Posted on Feb 27, 2008
My dell laptop keeps going back and forth from the loading logo screen to black screen
You might like to Power it off completely by removing the Battery for a few seconds.
If that doesn't help, try booting from your Win7 Installation Disk.
Apr 28, 2014 | Dell Studio 1537 Laptop
Well lastnight i set my laptop down and went to go do somthing for about 10 minutes i cam back and it was a blue screen, not thinking anything about it becuase this laptop has done it before i just powered...
you need to reinstall your operating system your files are corrupt so it will stay in constant boot mode until you reinstall if it doesn't work let me know
Mar 04, 2013 | Aspire Acer 7520-5071 Notebook
Windows dose not load
Unfortunately, This Sounds Like A Problem With Your Hard Drive/ Logic Board. You Will Need To Go To The Apple Store And Get Your Laptop Fixed Or Repaired... If you Haven't Done So Already.
Aug 22, 2012 | Computers & Internet
Dell inspiron 1545 14 beeps (more details inside).
This indicates a motherboard issue, sub out the ram memory one at a time, test each as you go, if no change! The motherboard will need to be replaced, or the laptop.
Apr 21, 2012 | Dell Inspiron 1545 Notebook
Ite mate I have a technika flat screen 32" and I
the output power of your inverter is not constant... it needs constant input...
Apr 27, 2011 | Inverter 1000-2000w Peak Surge Power
Battary is not chage its not working
What happens on almost all laptops is that either a: the solder breaks from the constant wiggling of the power plug in the socket causing the socket to become loose and not get a good connection, or b: the power supply module (the little box thing attached to the cord ) goes out, usually because people leave their laptop plugged in all the time, and it was never designed for long term constant use
The cord is only meant for charging the battery, or as a temporary power aupply in the event your battery should give out on you.
Dec 18, 2010 | Computers & Internet
I have a compaq v2401 cl, screen is turning black but when i pressed the lid button it turns back on for a while and after that goes back off.need help. thanks
This is likely an issue with power management- are you using the computer when the screen goes black? Or does it happen if you step away from the system...? If this is the case, go to control panel > power options and adjust the delay for your LCD turning off. If the situation is where the screen turns off constantly, that is an issue w/in the hardware of the laptop, and requires you to contact either HP or a local IT firm like Geeksquad or others for repairs to your laptop.
Oct 03, 2010 | HP Compaq Presario V2000 Notebook
After password wlecome then blue screen,need to hole power to do anything
Dear, you system's start up files are infected or disturbed. There is one way that can help.
1. start the system.
2. constantly press and release the F8 button to get system options and select the safe mode for start up.
3. if it starts up properly into the window, just restart your system.
if not then you need to re-install the operating system on your system, becuase such problems often occur due to the worms and virsus, and it may harm you further.
Best regards.
May 26, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Dell Inspiron 1100 Notebook Logo
73 people viewed this question
Alun Cox
