Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Kenmoore bottom freezer refrigerator door handles
We are moving and need to remove the handles from our refrigerator. It is such a big fridge that it does fit through any doors including the slider without the handles being removed. Thank you.
  • 828 Answers
This should be expired.
Posted on May 03, 2008
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
I woke up one morning and the fridge is not working but the freezer is working great. The fridge does not want to get any cooler than it used to be, it is not keeping our products cold. My fridge freezer...
the damper vent door between the freezer and fridge has stuck shut due to being frozen,you need to remove the freezer wall on the inside rear area to see if this door is shut and try to get it to move,also make sure the evaporator fan is running too so air gets moved from the freezer to the frideg
May 19, 2011 | Hotpoint RFA51 Bottom Freezer Refrigerator
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
How to move refrigerator handle to opposite side
In some cases they are designed in such a way where all you have to do is to remove the door and re-install it upside down to locate handle to the other side. Check to see if that's the case with yours!
Nov 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
I was given a Whirlpool ET1FTK 20.8 cu ft refrigerator/freezer. Door frame going thru is 29 inches. Need to take off doors of fridge to get in house. Anything you can send me. Don't have any of the books...
Start at the top and remove the hinge (5/16 socket). Slip the door off and remove the center hinge. Slip the lower door off and remove the lower hinge. Now is the time to reverse the door swing if it needs it. Move the handles to the other side and reassemble with hinges on the other side if you do.
Nov 03, 2009 | Whirlpool GB2SHDXP Bottom Freezer...
Move the handle to the other side?
it may be easies to remove doors, swap hinges to oposite side of doors and fridge.
For handle you will either have hidden tabs with screws to remove, pry off cover, or inside door panel
Aug 27, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Yesterday I purchased a 22 cubic foot GE side-by-side refrigerator, but I find that they won't be able to bring it in unless the doors are removed. (With the original fridge, which had a bottom freezer,...
Sould not be a problem to remove the door handles. If you look on top of the handle, you will see a large screw. Remove this screw and the handle should come free. Reattach the same way after you move the fridge in place.
Mar 09, 2008 | Refrigerators
Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Feb 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
205 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
