Question about Canon LaserClass 2060P Plain Paper Fax
Alarm setting I have the Alarm volume set at 3, but when we get a paper jam, the alarm does not sound.
  • xrayguy Feb 27, 2008
    The problem.... I can't get the alarm to sound off. The alarm volume is set to 3, but to no avail, no alarm.
    Scholar:
  • 159 Answers
The alarm sounds for only 5 seconds.When you receive a fax and the paper jams, the fax will be received into memory. When it has finished receiving the fax, the alarm will sound momentarily. When you remove the jammed paper, the fax will print automatically.
Posted on Feb 27, 2008
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
Dec 06, 2013 | Timex T309TT Clock Radio
I recently purchased a Canon PIXMA MX410 printer and was wondering if there was a way to turn the volume down when faxing? It is so loud. Thankyou.
Machine Settings
This section describes the items you can set or change in the Fax settings or Device settings menu available by pressing the Menu button.
For details on setting or changing, refer to the on-screen manual: Advanced Guide.
Sound control
Adjusts the volume of the audible tones, such as the keypad tone generated when pressing the buttons on the Operation Panel, the alarm emitted when there is an error, the offhook alarm that sounds when the handset is off hook, and the line monitor.
  • Sound control
    Selects the volume.
    • Keypad volume
      Selects the beep volume when pressing the buttons on the Operation Panel.
    • Alarm volume
      Selects the alarm volume.
    • Line monitor volume
      Selects the line monitor volume.
    • Offhook alarm
      Selects the alarm volume when the phone receiver is not put on the hook properly.
  • Here is the link to download the user guide as well:
    http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx410#BrochuresAndManuals
    I hope this helps
    Thanks
    Please rate FIXYA
    May 25, 2011 | Office Equipment & Supplies
    How to set an alarm on a Samsung T255G Phone?
    Hi there!
    You can set an alarm to alert you once, or daily at a specified time. Once set, the alarms are easy to change or turn off completely.
    1. In Idle mode, press Menu > Tools > Alarms. The following options appear in the display:
    • Wake-up Alarm
    • Alarm 1
    • Alarm 2
    • Alarm 3
    • Alarm 4
    2. Select an Alarm. The alarm screen appears in the display containing the following options: the alarm name, the on/off setting, the time, AM/PM, alert type, alarm tone options, the alarm volume setting, days if the week to sound, snooze option and auto power on/off setting.
    3. Highlight the options you wish to change, then select values for the options using the Left and Right navigation keys.
    4. When you're finished entering and selecting values for the alarm, press ok. The alarm is set and the alarm icon appears in the top of the display.
    Hope this helps
    May 01, 2011 | Cell Phones
    How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
    This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
    Setting Radio Alarm
    1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
    Setting Buzzer Alarm
    1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
    Activating the Alarms
    1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
    Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
    For the past two days, my alarm has been silent and I can't figure out why. I've tried putting the volume up, resetting the alarm sound and the alarm but nothing is working and the alarm still won't sound....
    The setting for the alarm is actually independent from the rest of the phone volumes. When you go the set the alarm and get to the alarm sound list, use the volume rocker on the side of the phone to set the alarm volume.
    For some reason, the Hero has a habit of screwing around with the volumes for the alarm. It happened to me a few times where my alarm got muted.
    Thanks for looking and good luck.
    Jan 24, 2011 | HTC Hero Smartphone
    No alarm clock sound
    The alarm volume is muted by default, and every now and then, it will reset itself to mute. I haven't figured out what causes it to reset (possibly reboots?).
    Anyway, in order to set your alarm volume, you will need to get to the list of alarm sounds. From this list, you can adjust the volume of your alarms using the volume rocker on the left side of the phone.
    There is no other place to set your alarm volume.
    Good luck.
    Mar 08, 2010 | HTC Hero Smartphone
    Htc hero alarm not working.... no sound when alarm goes off
    I had this problem with my Orange Hero too - there is a fix but it's quite obscure.
    When you're inside the "choose an alarm sound" menu and scrolling through the list,
    if you press the volume buttons on the side of the phone then you can manually adjust
    the alarm sound (mine was set to 0). Not sure what causes it to set to zero,
    presumably when you take the phone off silent mode it sometimes fails to update the
    alarm as well? This still needs looking at because it means the alarm volume resets
    to zero of its own accord, but it can at least be managed by manual readjustment.
    Hope this helps!
    P.S. It might also be worth noting that when I was having this problem, no
    third-party alarm apps would play the stock alarm sounds either.
    Oct 28, 2009 | HTC Hero Smartphone
    How do I change the radio station on the radio alarm
    Here is the full manual
    http://www.timexaudio.com/pdf/T311IB57574_35.pdf
    Here are the instructions from the manual.
    Setting the Radio Alarm
    Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
    appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
    flashing and you will need to press the
    Radio Alarm Button again.
    2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
    for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
    3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
    to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
    information on programming radio stations into memory, see the Programming Radio Station Settings section
    of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
    4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
    the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
    While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
    5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
    Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
    Aug 08, 2009 | Timex T311T Clock Radio
    Lost manual for a timex t307s
    Setting the Alarm 1 for AM/FM Radio
    1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
    you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
    need to press the 2 Radio Alarm 1 Button again.
    2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
    3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
    L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
    more information on programming radio stations into memory, see the Programming Radio Station Settings section of
    this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
    4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
    is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
    flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
    5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
    Indicator
    Setting Alarm 2 for Nature Sounds/Buzzer
    1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
    Indicator appear on the display.
    2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
    3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
    Sound #2: Birds
    Sound #3: Brook
    Sound #4: Wind Chimes
    buz: Buzzer
    4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
    5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
    display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
    Nov 18, 2008 | Timex (T307S) Clock Radio
    How to set alarm and ring with radio?
    Hi gidgid.
    This is direct from manual mailed to me from Oregon Scientific re my own contrast problem.
    1. Press [ALARM] to switch to display the alarm setting.
    2. Select ALARM 1 or ALARM 2 using [ALARM].
    3. Press and hold [ALARM] for two seconds.
    4. Use VOLUME [ + ] / [ - ] to enter the hours.
    5. Press [ALARM].
    6. Use VOLUME [ + ] / [ - ] to enter the minutes.
    7. Press [ALARM].
    8. Use VOLUME [ + ] / [ - ] to select ALARM or RADIO. If
    ALARM is selected, a two-minute crescendo alarm will be
    emitted at the set time when the alarm is active. If RADIO is
    chosen, the radio will be turned on for two hours at the set time
    instead.
    9. If RADIO is chosen, use [STATION] to choose the radio
    station and press [AM / FM] to select AM or FM.
    10. Press [ALARM].
    11.Use VOLUME [ + ] / [ - ] to set the volume of the wake up radio.
    12. Press [ALARM] to exit.
    Note: If there is no battery for the radio, there is no operation for
    step 9 ~ 11.
    sleepy head
    Jan 13, 2008 | Oregon Scientific RRM112 Clock Radio
    Canon LaserClass 2060P Plain Paper Fax Logo
    159 people viewed this question
    old marine
    old marine
