Question about Microwave Ovens
Repairs Microwave oven samsung RE 690 BF
  • William Miller
    William Miller May 11, 2010
    Hello, what problem are you having with your Samsung RE690BF microwave?
  • radarman19 May 11, 2010
    what about it?
2 Suggested Answers
  • 10 Answers
SOURCE: Pansonic Microwave Oven NN-S962-BF
Most likely the power capacitor is shorted.If you know someone that is just alittle familiar with electronics, they will know what to look for.The part will look like a somewhat long large silver 9v battery with two metal leads.Normally toward the back of the microwave and below the cooling fan.With a volt-ohm meter this capacitor can be checked.on the meter if you get a reading ,its bad, if you get no reading(open), its most likely good.Ninety percent of the time it will be bad.If it is, just replace with the same value and your ready to go.
Posted on Nov 06, 2007
Beeping sound with SE or 5e code
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see
See my profile picture if you need more help.
Oct 09, 2015 | Samsung SMH9187ST Microwave Oven
What is SMH18165 -Error code: E-13?
It is a T1 maximum time error (oven did not preheat properly). usually caused by a failing thermistor/sensor, a bad seal, bad control circuit board or connector. Unless you are a really good electronics expert and have the test equipment for after-repairs microwave emission measurement, it has to be dealt by the service people.
Read more
Jul 09, 2014 | Samsung SMH9187ST Microwave Oven
Shows SE and not working
The SE error indicates a short in the key panel. You can try resetting the microwave by unplugging it (or turning off the circuit breaker). Leave it off for a minute or so. If the code recurs, check if the microwave is under warranty. If it is still covered by the warranty, contact Samsung for repairs. If it is out of warranty, decide if it is worth sending the microwave in for repairs. (You'll have to pay a fee for diagnosing the problem; that will be applied to the actual repairs if you have the unit fixed.)
I hope this helps.
Sep 06, 2013 | Samsung SMH9151 Microwave Oven
I have a samsung microwave that has not been used just a few months,no longer than it is completely risted out and metal paint is dropping into the bottom everytime i use is. is it still good...
Speaking an a retired Samsung Main Repairs Agent, it is not covered by warranty, as the paint peels if left wet after cooking/steaming etc.
If you get into the habit of leaving the door open until it cools down each time, it would have given you good service.
Aug 06, 2017 | Samsung MW888STB 800 Watts Microwave Oven
I have a samsung microwave. Some of the paint is chipping off (under the revolving plate) and there are some scorch marks on the sides. I have heard of being able to touch up with microwave safe paint. ...
This is a special white enamel paint that is very hard to find, I don't have any personally but the manufacture use to supply the paint to people like myself to do touch up repairs. The only thing I can suggest is hound Samsung for the microwave paint because the magnetron will eventually short out making the oven useless.
Jan 27, 2011 | Samsung MW1080STA Microwave Oven
Door got slammed and now it does nothing
There are two or three switches operated by the door latches in a microwave oven. When the door is slammed, they can be damaged or knocked out of adjustment. If the control board thinks the door is open, it won't allow the oven to operate. It's best to let a professional check the oven and adjust or replace the affected parts. Microwaves are hazardous devices, with lethal voltages exposed when the cover is off. Also, repairs involving door repairs can cause microwave leakage if they aren't done properly. But once the switches are operating properly your oven should be fine.
Jan 08, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Sharp R-1490 microwave 2000
the fuse to the magnetron may be blown or the mag it's self is gone. if the door switch was bad the unit wouldn't rotate the carousel. if it is the fuse (check with a multi-meter and check continuity across both side of the fuse, acheap one will do) if it is good, time to replace the micro, as they are cheap and repair would cost more than to replace. hope this helps.
Mar 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Microwave make a deep humming sound ,does not heat and the circuit breaks
I would say your magnetron has failed.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the one-year time frame, the repairs should be free.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 24, 2008 | Samsung SMH7178STD Microwave Oven
My microwave stopped working and I'd like to try and fix it myself. Any suggestions?
Because microwave leakage can be hazardous and high wattage is present, limit your microwave repairs to light bulb changes if the light bulb is easily accessible. For other repairs, call a qualified technician to make repairs on a microwave oven. If it doesn't work and the light doesn't go on, be sure it is receiving power.
Jan 18, 2006 | Goldstar MA-7100 Microwave Oven
Microwave Ovens Logo
54 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
