Question about Konica Minolta Magicolor 2530 DL Laser Printer
Minolta 2530 DL duplex paper handling
I have just installed a duplex unit on the back on my color printer. It pushes the paper out (nearly) onto the output tray at the top and then tries to pull it back in to print side 2, but then there is a terrible sound of grinding cogs for 2 secs and then it stops with an error. Works just fine single sided.
  • WilliamW Feb 26, 2008
    Try removing the tape at the back of the printer!
    Champion:
  • 214 Answers
Also check that you installed the duplex correctly, that the gears fit into right place. gears are making this sound
Posted on Feb 29, 2008
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
Nov 17, 2010 | Konica Minolta Magicolor 5450 Printer
I have a Fatal Error Code: 17H Can you help? It is a Magicolor 2530 DL color printer.
Check your toner cartridges, one of them is seized up. Remove all cartridges and turn the gear on the right side backwards ( counterclockwise) about 10 times and see if it turns smoothly. I don't know why but 90% of the time its the cyan that gets stuck.
Jun 11, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2530 DL Laser Printer: reset image drum 2530...
I had this same problem however I was using the Magecolor 7450. I was trying to print a C5 postcard and the right hand side of the document was getting cutoff (aprox 2 in). Changing my Paper-Type settings on the printer from "Postcard" to "Any" magically fixed the problem.
I hate this printer.....
May 18, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error 17H
If the machine is under warranty then take it back to where you purchased it, or contact konica minolta directly and push for machine replacement.
Nov 01, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Fatal Error Code 16H
Hi, pretty sure its the transfer belt not able to turn, remove it and make sure there is nothing blocking it, maybe a paper jam
Aug 05, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Installing duplexer for Magicolor 2430 DL
quite easy, remove the cover tape, from backside and cut in the hole in backside cover, if nessesary. then fit the duplexer knobs into holes in backside. shoul work.
Dec 06, 2007 | Konica Minolta magicolor 2430 DL Laser...
Ink
There is a problem with your fuser assembly. It is not heating up enough to burn the ink onto the paper. This is usually replaced by a tech.
Sep 27, 2007 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
236 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
