Question about IdentityGuard Cross-Cut Shredder
REALLY LOUD I recently purchased the Identity Guard Paper Shredder and it is extremely loud to me. Is this normal?
    New Friend:
How do you oil the Identity Guard Model SH1524CP? The blades are moving very slow and does not always work when the paper is inserted. I have tried cleaning the unit
Posted on Jan 07, 2015
    Scholar:
  • 102 Answers
Your question should be able to be answered here 1-800-789-1331 I tried to find info on decibels but unlike FELLOWES they don't seem to provide that but try this number and they should be able to help you
Posted on Feb 27, 2008
Shredder won't turn on when plugged up
Shredders have a safety switch that won't allow it to run if it is off of the bin. Sometimes if the shredded is on the bin backwards it won't run because the plastic piece on the bin that presses the switch is only on one side of the bin. Sometimes if the switch goes bad, the shredder won't run.
Jun 21, 2014 | Techko Identity Guard 6-Sheet Strip Cut...
Identity Guard Model: SH9210PL
Do you have warranty? get it warranty repaired - replaced.
Let me know if you don't have warranty.
Jun 08, 2008 | IdentityGuard Cross-Cut Shredder
I have a privay Guard model PS-029/MB and I have a brocken plastic gear, can I find this part online?
I have the same problem. The gear that the motor drive shaft touches has been shredded to pieces. when contacting the second gear. The secondary gear is plastic and absolutely WILL shred itself to pieces over a short lifespan (<5yrs) because metal vs plastic is a losing combination.
Feb 02, 2011 | Techko Identity Guard 6-Sheet Strip Cut...
It makes a loud screeching sound, i think it needs to be lubricated. how do i lubricate it?
Sqirt shredder oil on a piece of paper that you want to shred & feed it through your shredder. Do not soak the paper a little is all you need.
Jan 12, 2011 | Fellowes Powershred C-320C Shredder
Yesterday when i was using it it started to make a really loud noise. reverse makes the normal noise but on auto it sounds bad. i cleaned out the inside but there is still paper stuck that i cant pull out....
It will not hurt to pour some lightweight shredder oil onto the cutting shafts....depending on how much you use the machine this should almost be part of a regular operation... I normally suggest to customers to pour the shredder oil onto a sheet of paper in an "S" pattern and then shred the sheet of paper....also shredders will work more reliably if you only shred about 70% of the rated capacity...less strain on the motor and parts and this results in fewer jams and longer machine life.
Oct 08, 2010 | Royal VF1012mx Shredder
Shredder doesn't want to shred in forward gear, have to Reverse first then switch it to On/Auto. Have to keep going back & forth between Reverse & On/Auto to get document shredded. Shredder is less...
Shredders became popular when the identity theft thing started happening and to save money they stopped making them with quiet, powerful induction motors and now it's almost impossible to find a consumer model without the poor quality loud motors that don't have enough to power to operate the machine once it's a little dirty. Anyway, unplug it, and you're doing this at your own risk, take the shredder off the trash can or its own waste bin and turn it over. If it's straight cut shredder you will probably be able to see the slot where the shredder paper exits the blade area. If it's a crosscut shredder there might be a door that will close over the blades to cut you from getting cut. Respect that, but open this door, and see if there's bits of paper jammed up around the blades. Wear some protective gloves and use pliers or some kind of tool to dig out the compacted trash, being careful not to damage or bend the blades. Now you should pick up some shredder oil from your local office store, or see link to order. Follow the instructions on the oil, and this will make your shredder run with a lot less stress. This is only a temporary fix however. In a couple weeks or months you will have to do this again. It's all part of owning a paper shredder. If you like it that much, look into buying a nicer model. You totally get what you pay for with a paper shredder.
Shredder Oil: http://www.officedepot.com/a/products/285661/Office-Depot-Brand-Shredder-Oil-4/?cm_mmc=Mercent-_-Google-_-Shredder_Supplies-_-285661&utm_source=Google&utm_medium=CPC&utm_campaign=plusbox-beta&mr:trackingCode=7646DB1A-EC81-DE11-B7F3-0019B9C043EB&mr:referralID=NA
Sep 16, 2009 | Shredder Office Equipment & Supplies
Overheating of identity guard sh9210pl shredder
This is typical... Make sure you lube the unit. Put the special oil on a piece of paper and run through per the instruction manual.
Sep 14, 2009 | Identity Guard 10 Sheet Cross Cut Shredder
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
Loud grinding noise when the shredder is on.
Your gears may be stripped - mine were. Time to get a new shredder
Jul 09, 2008 | Tech Solution TS-8000 Cross-Cut Shredder
IdentityGuard Cross-Cut Shredder Logo
331 people viewed this question
Top Identity Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Identity Office Equipment and Supply Expert? Answer questions, earn points and help others
