Question about Canon imageRUNNER C3220 Color Copier
Fax results page
I have a cannon Model c5185i and am unable to retreive fax confirmations. Also I am haveing problems scanning. Is there anyway you can assist?
  • 86 Answers
Try turning on fax confirmation in the fax user settings.
As for the scanning problems try downloading the latest scangear driver from canon usa website and load it.
if you require more help please get back to me
thank you
Posted on Feb 27, 2008
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Joe
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
Job failure but will fax anyway
ever thought of setting up the fax section of the computer
all you have to do is scan to the folder the fax the same as sending an e-mail
Sep 10, 2017 | Dell 2135cn All-In-One Laser Printer
Cannon mf 8350 Cdn confirmation of fax report
On the printers panel:
Press the "FAX" (actual button, upper middle)
Press the "Report" (actual button, upper right)
"Report Settings" (Press OK)
"Send Results" (Press OK)
"On" (Press OK)
Jan 17, 2012 | Canon MF8350Cdn AllInOne Laser Printer
MY HP Fax machine won't send fax, sends error what is wrong with the machine it's a 2007 Model 1040. when I am sending the fax after one page it beeps a lot and then feeds the rest of the pages. then on...
You either have a noisy or Digital phone line.
Have your phone company check the line.
I have NEVER seen a bad fax modem, unless it was fried by a lightning strike.
Apr 28, 2010 | Office Equipment & Supplies
How do I print a confirmation page for this fax
1. First You need to press the additional functions button on the front.
2. Select Report Settings button
3. Select Printer button under the Print List menu
4. Press either PCL button or PS button to print the appropriate config page.
5. Press Configuration Page button
6. Select Yes button to confirm printing of config page.
Feb 19, 2010 | Canon LaserCLASS Fax 710 Printer
L220 Cannon Fax tx function was not completed
It's possible you're not dialing the country's calling code or not dialing the correct sequence for international calling. To place a call out of the U.S. dial: "011 - country code - city code - number" The country code for Poland is 48. The link below contains the city codes for Poland which you may not have. Best of luck and I hope this solves your problem. Thank you for using Fixya and please remember to return to rate this answer.
International Calling Codes
Nov 26, 2009 | Canon ImageRunner 2020i Copier
Intermittently, the confirmation page on the fax says the fax failed (didn't go thru) but it actually did. Why is this? The confirmation page is printing false results, indicating the fax failed to go...
This is because some faxes don't have Error Correction Mode capabilities.
If there's a slight distortion on the line, the receiving machine (without ECM) receives a fax with some minor errors. And even though for a human eye the resulting fax page is perfectly readable, for the machine, that thinks only zeros and ones, there was an error detected in the data, and hence the trasmission failed.
Faxes with ECM when they detect an error, ask the sending fax to re-send the last portion of data, and this way can bring the transmission to a 100% successful end.
So the only thing you can do is ask your recipients to upgrade their fax machines to an ECM-capable model :)
Oct 29, 2009 | Canon Office Equipment & Supplies
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
Help with setting up my cannon mx310 fax machine.
here http://www.generalmanual.com/Printers/Canon-PIXMA-MX310-Office-All-In-One-Printer.htm you can download (under "download now" near the bottom of the page) the manuals you have lost.
Hope it helped you!
Dont forget rating.
Thx.
Jan 19, 2008 | Canon PIXMA MX310 All-In-One Printer
Confirmation Page
Check the link -- if this is the correct device page 44 of the first english manual has the code for changing the confirmation page setting.
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Plain-Paper-Fax/Copier/model.KX-FG2451
Dec 10, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Canon imageRUNNER C3220 Color Copier Logo
126 people viewed this question
old marine
old marine
