Question about Sony Handycam DCR-TRV250 Digital Camcorder
My camera function is not working
I can get power on the VCR function it will play a tape but when i switch to camera mode there is nothing going on the only thing i can get displayed in that mode is battery info
  • 1 more comment
  • onu1982 Jun 04, 2008
    Same problem here.
  • dwinfreyson Jun 22, 2008
    I have the same problem. It plays the tape, but when I switch to record, some yellow tape symbol pops up with a line crossing through it and an eject button flashes while beeping. So I CAN'T RECORD ANYTHING! And the thing broke right when we got to New York for vacation!!!!!!!!!!!!!!
  • ooberman Jun 23, 2008
    I took mine to a camcorder shop and the part was like 180 Dollars... so as cheap as the newer ones are i decided to put all our 8mm tapes on DVD's and look into the new mini 8's or the new disc type....
  • Sony Master
  • 2,794 Answers
It could be that the tape heads are dirty. You should try cleaning them with a 8mm tape cleaner. Radio Shack carries them.
Posted on Jun 22, 2008
I have a Panasonic VCR (DMR-ES35V) and when you insert the tape, it does not thread the tape across the video head. The tape runs for a moment and then ejects.
There's either damage in the drive section, or more likely and in some cases "plus" the Mode Switch is set in the wrong position or is faulty. The mode switch tells the electronics what position the VCR mechanism is in. Such as play or fast-forward. If in the wrong place it will carry out other functions - such as eject - in your case.
Sep 27, 2013 | Panasonic PV-V4022 VHS VCR
Err on display when insert tape, no functions work.
Two things. First there is some damage to the tape transport mechanism. Only a good look around will confirm this. Secondly a faulty mode switch.
Jan 14, 2013 | GE VG4250 VHS VCR
Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Feb 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
VCR will not switch to program mode
Solved my problem by reading a previous post about taking apart the remote and cleaning the contacts. Believe it or not it the remote is working again.
May 14, 2009 | Mitsubishi HS-U545 VHS VCR
Philips DVP3345V powers off after 10 seconds.....
If unit has auto rewind \eject feature? Try getting it into F Forward mode befoe it powers down....
Aug 26, 2008 | Philips Magnavox DVD/VCR Dual Player
If the all the functions of the camera work (EX zoom on off ) make sure you are using Panasonic tapes, other brand of tapes might not work, and if their is a menu screen go to settings and hit default, if no default found unplug take off the battier and let sit for 24 hours
Aug 25, 2007 | Quasar VM-D51 Camcorder
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
How can I play back a tape produced on the GRHD1U?
Tapes may be played back by the camera itself. If the tape was shot in the 720P (HD) or 480P (SD) modes, it cannot be played back on a standard DV VCR or camera. Tapes shot in the 480i (DV) mode are completely compatible and can be played back on any DV VCR/camera. In addition, tapes can be dubbed to a JVC HD DVHS VCR via the firewire connector.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony Handycam DCR-TRV250 Digital Camcorder Logo
88 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
