Question about Audiovox MMDV2
Wrong region code if zone 2 disc is inserted - Audiovox MMDV2
  • 39 Answers
MMDV2 Region change procedure:
1) Turn Unit ON
2) Make sure there is NO disc in the unit.
3) Press TITLE on the remote control.
4) Press 0,1, 6, 7 and then ZERO for all
region, 2 for region 2 etc
Posted on Jul 25, 2008
Wrong region
probably you are trying to play a disc that is not zone free or you need a code for your player to make it zone free. you may be playing a zone 2 disc ( PAL) on a machine that only takes zone 1 (NTSC) or vica-versa.
Feb 25, 2014 | GPX PD931BU Portable DVD Player
Regions hack for ALBA RDVD1000X1 Thanks in advance Mike Nelson
Try these
1. You can gain entry to the preferences menu BEFORE you insert a disc.
2. Turn the system on, to get the ALBA logo.
3. Do not insert a disc, but instead press SYSTEM on the remote control.
4. When you are in the menu, you can choose the region.
Another method:
1. Power on player.
2. Press Pause on the Remote.
3. Enter code 3, 1, 4, 1, 5 and 9.
4. The player display should read "COdE - -".
5. Enter the desired Region (0 = all, 1 = Region 1, 2 = Region 2 etc.).
6. Press Pause again.
7. Power off player.
8. Wait 10 seconds and then power on again.
Feb 05, 2011 | Televison & Video
Wrong region
Hi , The reason for the error message is because your DVD player is set to one specific zone. The below procesure will open the DVD player to play all zones.
TURN ON THE PLAYER
PRESS OPEN/CLOSE
USING REMOTE PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL APPEAR. PRESS "0" TO UNLOCK (OPEN the DVD player to ALL zones) ALL, THEN WAIT. INSERT YOUR DISC. Hope this helps. Let me know the status. Thanks, Mike
Nov 03, 2008 | Audio Players & Recorders
Hi there, have a Samsung DVDV6800 purchased in July that wont play all region discs. Can you tell me how to put in the codes for multi zones?
1. Power on your player with no disc in the tray. Wait for message "No Disc" in the top left hand corner of your screen.
2. Press and hold the Repeat button on your remote control for approximately 5 seconds.
3. Enter the code below. (Note that you must know what Region your player is currently set to in order to know which code is appropriate.)
for Region 1 use 2, 9, 3, 3 and 4
for Region 2 use 3, 8, 7, 6 and 7
for Region 3 use 5, 6, 7, 3 and 2
for Region 4 use 7, 6, 8, 8 and 4
for Region 5 use 5, 3, 8, 1 and 4
for Region 6 use 2, 4, 4, 6 and 2
4. The message "No Disc" will now be replaced with the default region number of your player. For example, Australian and N.Z players will display a small "4".
5. Press "9" for multi-region.
6. Open tray and insert your title.
7. Close tray.
The player will continue to hold the changes you have made. If this does work for you the first time, keep repeating steps 2&3 until the players default region number appears. The amount of time holding the repeat button does seem critical.
Sep 30, 2008 | Televison & Video
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Dvd dose not play
1. Insert any disc
2. Press Eject on remote (Once you eject, don’t pull the disc out)
3. Press DVD Setup on remote
4. Press 8800 on remote
5. Press DVD Setup on remote
6. Press Angle on remote
7. Region code number (0 : free, 1 : USA, 2: Europe)
8. Press (Skip Fwd) on remote.
Apr 20, 2008 | Blaupunkt IVOD-1022 Overhead LCD Monitor...
CODE REGION
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Mar 17, 2008 | RCA DRC247N DVD Player
Unlock LG DVD
The following hack worked for my player. It works for most LG and Aiwa players too. To hack the player try this:
  • Power on player with no disc inserted and wait for "No Disc" message on screen
  • (using the remote) Press PAUSE
  • Press the numbers 314159 in order. (player should now show "COdE - -" the same as below)
  • Press the number of the region you desire ( 0 = any region, 1 = US&Canada etc.)
  • Press PAUSE
  • Power off the player for a few seconds..power back up and insert your DVD disc
Jan 08, 2008 | LG Televison & Video
Region code
Oh the beauty of copyright. It's only put there to bypass anyway. Manufacturers spend millions of dollars to safeguard their copyright and some snotty nosed schoolboy beats the complete system in an afternoon. A good session of Googling may find you the code or push button sequence you need to disable the zone lockouts. If that fails it doesn't hurt to ask the TV salesman where you bought the TV. BMW
Jun 07, 2006 | Audiovox FPE-1505 15 in. HD-Ready LCD...
Audiovox MMDV2 Logo
192 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
