Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Jvc rear projection problem
One day we turned our tv on and the red was not lined up with the rest of the picture , it was like a red ghost of all the images. also the red was a bit curved at top and bottom. we also started getting a black fuzzy bar across the bottom, like it was eating up or picture or something. we took it to a repair shop and they said it is leaking?? and got on the mother board and is frying it. does this make sense to you? im trying to figure out if they are lying to me or not so let me know. they said it would be about 1,000 dollars to fix. and advice would be appreciated. thanks
  • cards7 Feb 26, 2008
    thanks bobby i appreciate the advice :)
    Sergeant:
  • 395 Answers
The problem you are having is the convergance amplifiers have failed there may be some resistors and fuses blown also.
now, this can be caused by coolant leaking from the guns shorting out the board.you may investigate this yourself by unplugging the set open the back and check for fluid leaks around and under the CRTs and on the main board. if it is present don't touch this fluid (eytholene glycol sorta the same stuff you use in your car coolant). if it is there then yes you are looking at a high cost of repair, but if not your looking around $350.00 or so.
Posted on Feb 26, 2008
My JVC wont converge the red lines so half my screen is good while the other has red lines. What should I do? Thanks A lot
The tv 100% have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors picture shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | JVC AV-48WP30 48" Rear Projection...
Ghosting of the image
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Red horizontal lines
Misaligned red lines in your TV is due to failure of Convergence Out ICs and requires replacement.
Let me know if you are familiar with TV repair to provide you part number info OR call local TV tech to fix the TV.
Thanks.
Apr 18, 2009 | JVC AV-48WP30 48" Rear Projection...
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC AV 48WP30 projection tv bleeding problem
You need two STK392-110 Convergence ICs. You can get repalcements at the following link, and they will provide free instalation instructions with picture so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 24, 2008 | JVC AV-48WP30 48" Rear Projection...
Ghosts on my tv
if you can, try hooking up the tv to a different cable line in the house or bring a different tv into the room where the bad picture is [ you may have a bad connection or wire ] if this doesn't help, try rabbit ear antennas just to get a picture. if you still have ghosts on your tv, the problem is with your tv.if the picture is fine, there maybe a problem with your cable service.
hope this helps
wg
Feb 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Red lamp gives off ghostly blurr
Red convergence IC is bad...replace both STK IC for durable,
long-lasting repair..............................T.
Dec 24, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
