Question about Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV
Our 42" Panasonic Plasma tv
Our 42" Panasonic Plasma tv (TH-42PWD7)after watching it for an hour or so , the picture shuts off, still have audio. I can put in a dvd and watch it , it never shuts off then. We've had it a little over a year (no kids so its not watched that much)
  • Anonymous Feb 09, 2009
    I will be watching TV, and probably every few minutes it just goes to a black screen for 2-5 seconds... Then turns right back on
    Problem Solver:
  • 8 Answers
As posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Posted on Mar 25, 2008
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Panasonic plasma TV TH-42PWD7 blacks out..
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 20, 2014 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Panasonic TH-C42HD18 42 In. Plasma TV inputs not working
yes. you find the main board for you panasonic plasma tv from shopjimmy.com.. good luck!
Sep 03, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
How i do tv chanel tunig
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
Dec 28, 2010 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Just shut off, no power
i have proble several time in a day
Nov 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have a Panasonic TH-42PWD7 flat screen it's hooked up to a receiver and a cable box from time warner. It's not mine. I'm staying at my friends house. I have sound coming through the cable/sat channel on...
There is sometimes a way to turn of the TV speakers, but it usually cannot be set that way by accident. Plan on audio board damage. Perhaps you fed the TV too loud an audio signal, then overloaded the amp board. I would consider them gone.
Nov 13, 2008 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Panasonic TH-42px75u Audio went out
re program remote codes 018,016,007,049,067,074,076.
you have to take your remote settings to default
Sep 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV Logo
277 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
