To by bypass this google id on ZTE Z835 you have to hard reset it & remove / wipe all of it`s data/settings. For this you can
With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
Press the Volume down button to highlight wipe data/factory reset.
Press the Power button to select.
Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
Wait as the device resets.
To Network Unlock it 24x7unlockcodes.com is the right place to unlock your zte Z835. You may need this when you are switching your sim card for change your network or visiting abroad. You can get your unlocked permanently by our hassle-free procedure in a competitive price online at your door step!!! Just order us & relax at your home, we e-mailed you once it done.
Use of unlock code for Zte Z835 network unlocking is totally legal. We insured you that our service will not change any feature or behavior of your Zte Z835. The data in your Zte Z835 will also remain protected. Under circumstances like, If the code will not successfully derived by us or will not work on your Device, we guarantee our customer fully refund of their money.
You can reset the device back to factory setting by holding the power button for 15-30 seconds. CAUTION it will clear away your address book and any custom set ups you have done. You also might contact your cell phone provider
Try these steps:
ZTE Origin hard reset
Master Clear/Reset Cricket Origin reset ZTE V768 ,
1. Make sure your phone has been powered off. 2. Hold down Volume up key and press Power key at same time until the screen lights up. 3. Press Home Key to access Android System Recovery screen. 4. Press Volume up\down key to locate wipe data/factory reset, then press Menu key to access factory data reset menu. 5. Select Yes-delete all user data, then press Menu key to confirm wiping data from the phone.
6. When finished, select reboot system now, then press Menu key to restart your phone.
Every data will be erased!
or You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
or from the menu
Privacy: Reset to Factory Settings
1. Touch the Home Key > Apps icon > Settings > Privacy > Factory data reset > Reset phone.
2. Enter six zeros on the screen and touch Erase everything.
WARNING! All your personal information and downloaded applications on your phone will be erased after the factory reset.
ZTE Origin V768 Phone Password
A password can protect your phone and help prevent unauthorized use. When the phone is password protected, it will ask for the password every time the phone is turned on. Password protection is disabled by default, and the default password is 000000 (six zeros).
Warning Hard Reset will erase everything on your Device !
1. From the Home screen, press the Menu Key and touch Settings.
2 Touch the Privacy
4 Touch Factory data reset.
5 Touch Reset phone.
6 Touch Erase everything.
Press the Emergency call and enter *983*987#, the phone will go to the factory reset interface, and then press "Erase everything" (Don't check Erase SD ard). Finally, the phone will reboot by itself and there is no unlock and password any more after the phone is on.
