Sending and rec faxes
HP 920 The fax machine will ring but says "fax not answered" also cannot receive. It does tell us that there is a fax being sent. Not sure if it is the fax or phone line
  • jmwills1960 May 05, 2009
    i have not received any fax today or send any everytime i send a fax it is busy
    Scholar:
  • 159 Answers
The protocol is failing after the check frame is received. Most likely noisy tel line, but could be attenuation problem. Either way, have the lines checked by telco.
Posted on Feb 27, 2008
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
I have a hp 2200 all-in-one printer. For some
if it sends ok, then it has probably been switched to "manual receive" form "automatic mode"
Apr 21, 2009 | Office Equipment & Supplies
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
Rings to Answer setting is five rings.)
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
tray.
3. If you are currently on the phone with the sender, instruct the sender to press
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
133 people viewed this question
jasbo
jasbo
