Question about GE JBP15 Electric Kitchen Range
Oven not working
When i turn on my oven i notice my automatic oven light does not come on and the oven does not heat at all and if i put it on clean the automatic oven light comes on but it still does not heat. The range works fine. I have unplugged it and tripped the breaker to reset it but it still does not work. What else can i do?
  • alews Nov 24, 2008
    I had to replace the baking element. When I plugged it back in, I started the cleaning process. After a few minutes, we heard a "pop" sound come from the stove top part. All of the burners heat up, but my oven now does not heat up at all and we are four days from Thanksgiving. HELP!!!!!!!!!!!!!!!
  • 417 Answers
I believe that the oven dial that turns to start the oven not cleaning has either a loose connection on the back or that the dial is faulty and will need replacing.
Thanks J
Posted on Feb 26, 2008
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    hello,
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    Top oven does not heat-although bottom oven is ok.
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 29, 2010 | Whirlpool GBD277PD Electric Double Oven
    After light cleaning-Electrolux Ew30ES65 upper oven won't heat now! The bottom oven works fine, the lights are all on, the convection fan works in the upper over but the heating elements don't heat now....
    I had the same issue with my EW30EW55GS. This is the second time! The dirst time, the technician replaced all the circuit boards (took a month to get the parts). I figured, I would try a light cleaning again. SAME THING! Again, I'm without an oven for no telling how long. The oven looks great, but don't be fooled - it's a piece of junk!
    Apr 04, 2010 | Electrolux ICON Designer E30SO75ESS Oven
    Turned on self clean on my GE Spectra JBP24B0B4WH Range
    Hello Cliff Hendershot,
    One USA manual ... said turn off power for 10 minutes
    (sounds reasonable after looking up cost of control board)...
    USA websites are not responding to your number.
    Closest I could get was to a $78 (us dollar) control panel
    >> ((IMPORTANT PART ... has a video that shows repair))
    http://www.appliancepartspros.com/ge-oven-control-t09-wb27t11312-ap5177950.html
    I could NOT get a good READ on your JBP24... page 8
    So I attached a JBP19 (below)... Page 12.
    The most COMMON reason to FAIL after a cleaning cycle
    is your OVEN CONTROL is "off normal"
    (You still do not have your MANUAL MODE restored).
    Normal = "AUTOMATIC" LIGHT Off (NOT LIT)
    Check your "oven controls"
    else
    Oven elements do break during routine use...
    Check both roast & bake elements for continuity.
    GE JBP19 Owner Manual Usingthe Oven
    Carnac the Magnificent
    Jun 08, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven will not heat - Thermador SMW272 Electric Oven
    since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
    Dec 12, 2008 | Thermador SMW272 Electric Double Oven
    Clock assembly
    my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
    Mar 21, 2008 | Jenn-Air SVE47100 Slide-In Electric...
    GE JBP15 Electric Kitchen Range Logo
    122 people viewed this question
    Top Kitchen Ranges Experts
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Sal De
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
