Question about HP DeskJet 970cxi InkJet Printer
Deskjet 970 unable to get test
Suddenly i can not get the utility to provide ink levels, print a test page or calibrate. an error 1101 appears, and it wont do anything. it will print and im low on one or the other cartridge. but dont know which. the copy is printing in blue- which leads me to think that black is out.  but.. not sure. suggestions? I already shut down and restarted the computer and the printer.
    Genius:
  • 3,587 Answers
Ok...first...low color will do that blue effect..
and, you may need new drivers
remove old ones first
go here for fresh set
then reinstall
Posted on Mar 24, 2008
How to turn off test print on a HP DJ 6122.
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 06, 2014 | HP Deskjet 5940 Photo InkJet Printer
Server 2008 drivers for HP deskjet 6122
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with many Windows systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch.
Jul 04, 2012 | HP DeskJet 6122 InkJet Printer
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
I have a HP Deskjet 6122 Printer and I need a driver for Windows 7 that I can load on a flash driver to put on another computer
Windows: "Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are resident/included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 14, 2010 | HP DeskJet 6122 InkJet Printer
HP Deskjet 722c appears to print but the page is blank. New toner cartridges have been installed
If the clean test page shows streaked or broken colors, the printer or cartridges are not functioning properly. Note that HP cannot guarantee the quality of refilled or remanufactured cartridges. Follow the steps below to solve the problem:
  1. Remove and reseat the cartridges. Try printing again.
  2. Check ink levels, and if a cartridge is low on ink or out of ink, replace it and try printing again.
  3. Clean the cartridges. Depending on what printer you have, you can either print another clean test page or run a cleaning utility. Check your User's Guide for instructions. Try printing again.
  4. Clean the contacts, then try printing again. Click here to see how .
  5. Align or calibrate your cartridges (depending on what printer you have). Check your User's Guide for instructions.
  6. If none of the steps above have helped, clean the nozzle plate manually. Click here to see how .
  7. If the problem still has not been solved, replace the cartridges or service the printer. Click here to see how to decide which to do .
Feb 13, 2010 | HP DeskJet 722c InkJet Printer
Can i install the HP Deskjet 6122 on a brandnew HP Laptop with vista OS?
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Oct 10, 2009 | HP DeskJet 6122 InkJet Printer
I am getting unwanted black stripes when i do colour-printing. on my old pc i used to be able to clean/test the printing head but i dont have that facility now & can't see it on the net. any tips...
First run a cleaning cycle and test print. You can get this from Control Panel - Printers - Select Printer name and right click - select Properties and then Maintenance.
Then
1. Select Normal or Best, rather than Draft, in the Paper Type/Quality option in the Page Setup Screen.
2. Align the print cartridges. Select the Calibrate panel on the HP deskjet utility screen, then click the Align button.
3. Decrease ink density or drying time.
a. Click File > Print > Paper Type/Quality.
b. Click the Ink tab.
c. Use the sliders to adjust ink density and ink dry time.
Oct 07, 2009 | HP DeskJet 960c InkJet Printer
Turn on printer and light continues to flash. Not
What the flashing light means
The Power light can flash for several reasons:
• The printer cover is open.
• The printer is out of paper.
• A problem exists with the printer, such as a paper jam or a problem with a print cartridge.
If an error message appears
Read the error message that explains the problem and its solution.
If no error message appears
Check the status of the printer by using the printer tools. To gain access to the tools, open the Printer Properties dialog box, click the Services tab, and then click the Service this device button.
Use the printer tools to perform the following tasks:
• View estimated ink levels.
• Clean the print cartridges.
• Calibrate the printer.
• Print a test page.
• Perform other functions as needed.
Jul 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
Aug 14, 2008 | Office Equipment & Supplies
Unexpected Error (1001)
I have exactly the same problem, only my Deskjet is HP 3840 and I am running a PowerMac G4 with OS 10.4.10.
Dec 11, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 970cxi InkJet Printer Logo
149 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
