Hi, please can anyone help, I have bought a second-hand Z310i and don't have an instruction manual. At the top left of the screen you have the signal, then the blue tooth, then the mail and then what looks like a block of flats! what is this?!
thanks.
To delete stored files on the disk, look for the Access Stored Files icon on the main menu screen. (The manual shows the icon as either the right-most one on the top line or the left-most icon on the second line.) Press this icon to get a list of storage locations. Choose the storage area and then an individual mailbox, if you select the Mailbox icon. Select a file and press the Edit file button (second button from the left) below the list. The Delete button should show in a windows as the top left button. This function may be limited to the internal mail box that you can access.
If you need one of the stored documents, consider using the Send or Print options. The send or print the file by choosing the Delete after Send or Delete after Print buttons on the right side of each of these screens.
Hi I have just bought a second hand Bush Alarm Clock Radio with iPod and iPhone Docking CCR232i Black.
Unfortunately it doesn't have the manual and I have spent ages trying to find one on the het to no avail,
would anyone know where i can find one please.
Any help would be much appreciated :}
Since you know you cannot transfer your contact from the phone to the sim because of the blank screen, it means you have to replace the screen of the phone in other to access the menu. I will advice you to take your phone to a technician to fix the screen.
This just happened to me, the solution is to wiggle the top half a bit (like you wanna break it, but don't break it.) The root of the problem is a loose wire that connects the two phone parts. Mine still goes blank on me but then i wiggle it... just a little bit...
hi if you email body sculpture on [email protected] they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Click the "Home" icon on the bottom of your touch screen, which is the first icon from the left (the tiny picture that looks like a house).
On the left-hand side, click the fourth icon from the top, second from bottom (the one that looks like a picture of internal clockwork). This will be "System".
Click the first icon, also a picture of internal clockwork. This will be "Settings".
Click the second option from the top. This will be "Phone Setup".
Click the third option from the top. This will be "Language". Select the very first option, in this case, will be "English".
The instruction manuals for Panasonic products are at the Panasonic UK
website. The address where I found the manual for the Panasonic
SD-BT10P is here:
Just fill in your model number, click enter. Look below the form where
it says "Available Downloads", click View 4.2MB. On the page that
opens, click I accept, on the left, a little way down from the top of
the page, then click on "view" and it will open. You can save the file
by going to the top of the page, click on the second icon from the left
at the top of the page. The one that looks like an old floppy disc. I
would suggest renaming the file so you know what it is, then save it to
wherever you save your files and you're done!
Problems? Email me and I'll attach it to an email for you.
