Question about KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid KGRA806PSS
Oven Door Locked after Clean cycle and panel is blank Kitchenaid kgsk901s gas, Self clean cycle shutoff, door's locked, panels black, it's got power to the gas top ignitor. It won't open, is there a reset?
  • 2 more comments
  • turbulance Mar 01, 2008
    Ya the door is still locked. How do i get into it? Will the door come off any other way? Any reset?
  • turbulance Mar 02, 2008
    I got the door off. What caused the power outage in the gas range, a sensor, or main panel meltdown?
    What do i do next? Is there a reset buttom to get power back?
  • turbulance Mar 03, 2008
    My gas range shut off in a cleaning cycle. The panel has no power, I had to take the door at the hinges because it was locked. The oven latch looks to be still in the hooking position so I wired it to not latch when I put the door back on. How do I get it working again?
  • 2,322 Answers
Check HERE for more info.
Posted on Mar 03, 2008
    Genius:
  • 3,587 Answers
Hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Posted on Feb 26, 2008
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Mar 01, 2008
    yes...unfortunately, you'll need to tip if up, and get to that release from the underside(Nice, huh?)..
  • Patrick Michaels
    Patrick Michaels Mar 02, 2008
    most likely a sensor..the main panel would have been affected by an external power glitch, just like a computer might have. What condition is the panel in, physically?
  • Patrick Michaels
    before you go in that direction, does the unit work, with the door off?
Kitchenaid KGSS907 oven door locked after self clean mode, what I must do?
Thermostat at the back/rear might have blown.
Is the oven still working?
Then the door actuator motor may have failed.
Jan 27, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid KGSS907 oven door locked while in self clean mode
It locks so you dont open it during the cleaning cycle. It gets very hot so it burns everything stuck fast to a crisp. after cycle is over and temp drops it will unlock. dont worry about a small amount of fire as long as it dosent get too big it should be fine. Might make alot of smoke though.
Dec 27, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
The oven door is locked after a self cleaning yesturday. None of the lights on the control panel are on and I can't get any of the buttons that control the oven to work
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 09, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Door locked: display panel not lit.
Unplug the appliance and the next day it will work again. Do not use the self clean cycle or I will have to spank you! Did you not know that 900 degrees for 3 hours can harm delicate expensive electronics. Get some easy off and clean that oven or get ready to spend some serious dough on fixing this puppy down the line.
Apr 10, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Lock on oven is locked and door open
look towards the center of the door, next to the "self clean latch" youll see a thin metl "plunger", try pressing this in and then restarting a clean cycle, then quicklly cancel clean it should reset the lock/latch mechanism
Jan 21, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven shut down
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
try pressing stop/clear press and hold timer for 5 seconds after making sure there is piower to the range
Jan 22, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
KitchenAid convection oven - panel went black during self-clean SOS
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
Nov 22, 2007 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
453 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
