Question about Samsung HCM422W 42" Rear Projection Television
Samsung 42inch model number sp42w5fx
The focus seems 2 have gone, pressing the autofocus only shows me the green focusing is this a bulb problem or has something else gone in it?
    Genius:
  • 2,920 Answers
Your tubes may be getting weak
Posted on Nov 05, 2008
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
Jan 03, 2015 | Samsung DigiMax Cameras
The manual focus ring on my camera doesn't work. The ring turns but does not seem to adjust the focus. Automated focusing still works. How to fix it?
Two methods:-
1. Use the slider switch on the left of the camera to set it to MF (manual focus). The focus ring is an electronic one rather than a physical control like the zoom ring, so the response can seem slow.
2 Go into the camera menu and enable DMF (Direct Manual Focus). This allows you to override the autofocus simply by adjusting the focus control, but it does not work if the slider switch is set to the AF C setting (continuous autofocus), it only work in the AF-S (AF only activates once when the shutter is half pressed).
Jan 31, 2011 | Konica Minolta DiMAGE A2 Digital Camera
Kodak P880 camera won't autofocus. I bought a used P880 - seems like an awesome mid-high end camera for someone on a budget. Problem is that it won't autofocus properly. When viewing and pressing down on...
Hi mfkcolumbus,
Did you check the firmware version? If it's not v. 1.02, then get it at the Kodak support site and flash that firmware to your camera. If it is 1.02, then you may try to reflash that same firmware. Sometimes this helps strait'n out things.
Hope this helps.
Gr. Blackbear
Jun 27, 2010 | Kodak EasyShare P880 Digital Camera
How do you turn off autofocus on Mini DV Sony Handycam?
this is how you disable autofocus for this camera, first set cam to camera mode.using touch panel screen:
1.press FN to display PAGE1
2.press FOCUS
3.select and press MANUAL
4.select and press (icon of person) when subject is too close to focus on or (icon of a mountain) when recording distant subject
5.press (return arrow w/OK) to return to PAGE1
hope this info helps.tnx:)
Apr 16, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
I have M1033 - when the shutter button is pressed half way down it wont focus and shows a red AF on screen. The pics are blurred. Batteries have been changed and lens cleaned.Help please
The red AF is autofocus. If it is red it isn't focused. You will have to hold the button until the red light turns green, then release the button.
Jul 08, 2009 | Kodak EasyShare M1033 - black Digital...
G1 phone camera doesnt take pictures
As the others said, there are the two settings. I had a similar problem, then realized how it worked. You need to not press very hard while it focuses first. Then you can press all the way down, if you hold it all the way down, it doesn't recognize that you've already passed the first "Focus" pressure point and gone into the second "Capture" pressure point.
Oct 25, 2008 | HTC G1
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Nikon d40 autofocus
This happened to me once on a D70... When mounting the lens, make sure it clicks in all the way when turning counterclockwise. Also it may be worthy to note that both the lens AND the camera must be set to autofocus mode ("A" switch set on both lens and cam).
Marky
Nov 25, 2007 | Nikon D40x Digital Camera
What am I doing wrong?
This depends on which Autofocus system that particular model uses.  Then manual should tell what is happening there- there is usually a more comprehensive manual on the supplied CD.
Failing that speak to the user support of you particular model
Oct 25, 2007 | GE E1040 Digital Camera
Samsung HCM422W 42" Rear Projection Television Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
