VPR matrix 2250 motherboard configuration to connect the wires I disconnected to change another motherboard. Now I cannot reconnect all the wires. Can you help me? Thanks, Teg
    Genius:
  • 1,019 Answers
You Need to go to The Motherboard Manufacturers Web-Site.
And Download A User Manual For That Model.
You can,t guess Or assume which wires go where, or your likely to damage the mainboard.
** Please Note** All motherboards Differ Slightly Unless you Purchase A Identical replacement.
Hope This Helps Mike @ Compurepair.
Posted on Feb 27, 2008
1986 dodge caravan heater troubleshooting, not heating the vehicle
try bleeding the heater matrix out to remove the air,with the heater switched to hot,disconnect the out flow pipe from the engine end with the motor just warm, (so you dont scold yourself), till water flows well then reconnect pipe and top up system, if theres no flow then you need to flush the matrix out by disconnecting both water pipes and connecting a hose to the in flow of the matrix and flushing out till water runs out the out flow end,then reconnect hoses and bleed out, top up rad or heder tank and check anti-freeze.
Feb 08, 2013 | Dodge Caravan Cars & Trucks
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
How many 512 mb memory sticks can be installed in a vpr matrix 226r PC
all that you want , just check the mhz speed, must be the same
Sep 28, 2010 | Matrix 226R (VPR226R) PC Desktop
I have a VPR Matrix model 2250 since new. I was vacuuming the inside of it and all circuit boards and accidently knocked the connection cable loose on the mother board which goes from the start push button...
No, VPR Matrix doesn't show information.
http://www.vprmatrix.com/products_desktop_2250.asp
That's okay though. I would like you to take a flashlight, and view the motherboard closely. I need to know who made the motherboard, and what the model number is.
FIRST!
With all Due Respect, I would like you to STOP, (Not shouting), using a vacuum to clean the inside of your computer out.
The vacuum creates Static electricity. Static will FRY OUT the hardware components inside your computer. POOF! No computer!
You may have already done this repeatedly, and have had no problems. All it takes is once.
For a test. Put the wand attachment above your head. Bring it to about 1 inch above your hair, parallel to the floor, and the nozzle end beyond the front of your face.
Have someone turn the vacuum on. Your hair lifts up. This is caused by Static.
Thank you for letting me say that.
It is Much better to use a can of compressed air for computers. Yes, I know it costs more, but it's cheaper than buying another computer.
(About $6 to $8 USD)
BEFORE you reach inside your computer, unplug it from power. ALSO, touch the metal frame of the computer case. This will relieve Static from your body.
Now you are safe, and your computer is safe.
(Work on a table. A Bed, Couch, or directly on a carpet floor are High areas of Static)
You may have to move cables to the side, and accidentally touch components inside your PC.
Look in the center of the motherboard. Also look near the edges. One more common place is in-between the expansion slots.
Expansion slots examples are, PCI slot {White in color},
AGP slot, {Usually Brown}
Due to the hardware components listed above in the VPR Matrix link, I don't think you have a PCI-Express slot.
This gives more detail about the PCI expansion slot, and AGP slot, for identification,
http://en.wikipedia.org/wiki/Motherboard
Look at the photo on the upper right of the page. You can click on the photo to enlarge. The long white slots at the top of the motherboard, are PCI slots. The long Brown slot is an AGP slot. All are Expansion Slots.
On the motherboard you will notice ASUS. It is upside down in the photo, and in-between the brown AGP slot, and the third white PCI slot.
That is the motherboard manufacturer's name. Asus
To the left over by the blue ram memory slot is the Model Number.
It's on a white strip.
A8N-VM CSM Revision 1.10
If I have this information I may be able to find the Motherboard Manual.
I will give you the link to it, and also detail out where the Power On switch, (Button) wires go.
They will go to a Front Panel header on the motherboard. We just don't know where yet. (Connector on a motherboard is called a Header)
Don't worry, we'll find out where those wires go.
Nov 29, 2009 | Matrix Computers & Internet
Upgrade for a Ti4200 Graphics Card
i think the best graphics card you can get for your pc cause its AGP slot is a 6200 from nvidia.
May 15, 2009 | Matrix 226R (VPR226R) PC Desktop
I can't connect to the wifi even in taskbar it shows that wifi is connected and signal strength is also very good. mine is acer aspire 3680. please help. also tell how to install lan drivers.
Hi Dear. Verify DHCP or Manual IP configuration from AP/WIFI Router. Disconnect and Reconnect and follow IP configurations as mentioned in AP/WIFI Router.
Feb 26, 2009 | Intel D865GBF Motherboard
VPR Matrix 226R-Blank screen when powered up,LED in front blinks
Not a power problem. Could a memory problem try changing the memory (DDR SDRAM), see if monitor comes on and if the system does a POST (power on self test) That should indacate any further problems if any.
Dec 06, 2008 | Matrix 226R (VPR226R) PC Desktop
Installing RAM in VPR Matrix 2250 Desktop
try one stick at a time ,as one may be bad,
also ensure you have them in the slot the correct way round ,as they will not seat down correctly if inserted wrong, take notice of the notch on both ram stick & ram slot.
good luck
Terry
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
794 people viewed this question
David Payne
David Payne
