Question about Brother MFC-8460N All-In-One Printer
Crinkled paper When we print the paper is coming out crinkled. Please help?
  • 99 Answers
Pop open door to make sure nothing is stuck near rollers. Could be paper, staple, paperclip, etc. Clean out and try again.
Is it the same paper you always used?
Posted on Mar 24, 2008
  • 2072 Answers
SOURCE: PAPER CRINKLING
First check the paper path for something in the paper path. Staple, paper clip, etc, causing the paper to twist. Reseat the imaging unit and see if the transfer unit is seated properly.
But, What sounds most likely is that the fuser needs to be replaced. The rollers are most likely getting pretty bad inside that unit.
If I recall correctly, it is in the $200 range to replace.
Posted on Feb 16, 2008
SOURCE: crinkled paper
It sounds like a fuser problem. You may have something stuck in it, or the lower roller could be defective. You may have to replace the fuser.
Posted on Nov 03, 2007
SOURCE: paper has creases or is crinkled
We have had it worked on 2 or 3 times in the last six months and it is still doing the same thing.
Posted on Aug 26, 2008
  • 3 Answers
SOURCE: Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Posted on Feb 02, 2009
  • 138 Answers
SOURCE: cannot change the rollers due to crinkling papers
You problem is with the fusing assembly in the rear of the machine. This series of Brother are famous for it. If you open the back door you can get access to the fusing compartment. The fusers aren't cheap though, around $100 to 125.00. Cheaper to buy them from Ebay than through a dealer (and I am a dealer) as there are folks that are just taking the machines apart for parting them out. Just make sure you go with a new fuser, not used.
Posted on Nov 16, 2009
Why is my printer printing crinkled paper?
check the fuser and replace it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 14, 2014 | Konica Minolta bizhub C450P Laser Printer
Printing Crinkled paper
replace the fuser unit
When printing paper comes out all "crinkled" maybe roller problem?
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Apr 26, 2010 | Brother MFC-8660DN 5-in-1 Laser...
Paper catching
the paper sensor could be bad, try manually selecting the paper type, plain paper etc...
Mar 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Only on Quicken to 3210 all-in-one printer. Paper starts to feed then indicates paper jam, wait long enough and paper feeds with crinkle and no print.
I would check the paper path on the printer where it is crinkling the paper. More than likely there is some small piece of paper or something that is causing it. Does it only do this out of quicken? I wouldn't think so if the paper comes out damaged....
Feb 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
PAPER CRINKLING
Feb 16, 2008 | Xerox Phaser 6250DP Laser Printer
Crinkled paper
Nov 01, 2007 | Lexmark E320 Laser Printer
Brother MFC-8460N All-In-One Printer Logo
304 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
