Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis Francis X1
Hi, My newX1 is leaking water from between the body and the upper ground/pod holder. That is to say when I turn on the unit, before I put in the ground/pod holder, I get 2-3 teaspoons of water leaking out while it heats up.
It stops once it has heated up, but it happens every time.
Thanks for your help.
  • 3 Answers
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Posted on Jul 14, 2008
Ground Coffee Kit/Holder
There were two versions of the Francis Francis X1; one without the logo (older) and one with. I guess your only chance is ebay; but why would someone sell the holder without the machine?
May 27, 2014 | FrancisFrancis! X1 Espresso Machine
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
When I turn on my Francis Francis it blows the
Hi
you have a blown element and is grounding the machine through the boiler.
Apr 02, 2010 | FrancisFrancis! X1 - Stainless Steel...
My francis and francis is leaking and the espresso
Hi
Try calling Illy at 877-469-4559. They can help you get your machine fixed.
Jul 15, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
I have a Francis X1 Trio. Has anyone ever tried to use ground coffee and can it work. I hate the pods and would love to try to use regular ground with a tamper, but I'm afraid of ruining the machine.
You need a ground coffee adapter, these are available from various sites online. Do a web search for X1 ground coffee handle and you'll find one. Make sure it's the right one for your machine (check to see if you have the aluminium or brass boiler version)
Just found this site - It's in the UK and I'm not sure if you are but they will probably export to you.
http://tinyurl.com/lhxvg6
Regards
Richard
Feb 18, 2009 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
610 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
