I have a Problem with a Compaq nx6310 as soon as i turn it on their is no video.. but power it gets.. i tried to turn out the ram but no help i tried to change hard-disk no help.
hope of Help
Devil
Hello devilgod1209,
The memory and hard drive shouldn't be the issue. Most likely your LCD has stopped working or the inverter for the LCD panel's back light has stopped working. Try shining a flashlight directly at the screen and see if you can see any windows, icons, etc. If you can then the back light has gone out or the inverter has failed. If you still don't see anything your LCD panel may have failed. Try hooking up an external monitor and see if you can get an image to display on it. If so then you may need a new LCD panel installed. At that point you should probably take it to a repair facility or see if your warranty will cover the replacement.
Hope this helps and good luck. Don't forget to vote and leave feedback.
