Question about Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard
CPU model not recognized correctly
I have a Biostar mobo Model M78VIG 400, and I am trying to upgrade the CPU to an AMD Athlon XP 2600. I updated the bios recommended by the vendor, changed the frequency jumper to 133Mhz (it has a thunderbird core), but the bios still only see the CPU as an Athlon XP 667Mhz. What am I missing?
  • 2 more comments
  • need2breakit Feb 26, 2008
    Sorry, messed up the model. It's a M7VIG 400.
  • need2breakit Mar 12, 2008
    I would check the bios if I could, but it doesn't get that far. Either I get the BSOD or the OS keeps chugging and never fully boots. I didn't see any multiplier settings in the bios, which I thought was strange. But that's what I'm asking, is there some multiplier setting in the bios that perhaps isn't called a multiplier setting, but called somethings else, and that's why I keep missing it?
  • dspear Mar 24, 2008
    I am having the same problem. I have a ECS K7VTA3 V8.0 motherboard. I was running a Duron 1800 with no problems. I bought an AMD Athlon XP 2600+ (266Mhz FSB) CPU and when I start the computer, the CPU is recognized as an Athlon XP 667Mhz. I can get to BIOS and up the clock rate but there are no options for multipliers. Same problem exists with the same CPU on my ECS K7S5a Pro. Maybe I have a bad CPU???
  • Anonymous Mar 31, 2008
    cannot boot 2700xp
I updated the BIOS and just installed an Athlon XP 2200+ in one of these boards. At first, it recognized it as an Athlon 1600. In the frequency control section of the BIOS, it allowed me to set it as high as 132. After changing it to 132, the BIOS showed the CPU as an Athlon 2200. I've benchmarked it and ran stress tests off of the UBCD and it appears fine.
Biostar reports the board as accepting Semprons and other CPUs up to 200mhz FSB speed. Go figure. Your best bet is to upgrade the BIOS and then set the clock to 132.
Posted on May 20, 2008
    Genius:
  • 1,066 Answers
Any multiplier settings in bios? try using something like CPUID in your OS to see if it clocks faster then what bios tells you?
Posted on Mar 01, 2008
I need a m7vig400 supporting prossers
You can see the supported CPU list from Biostars web site;
http://www.biostar-usa.com/cpusupportA.asp#M7VIG%20400
Listed under Model. Scroll down the CPU list untill you come to M7VIG 400. Highest CPU supported is, AMD Athlon XP, 3000+ (333MHz)
Main web site for the M7VIG 400;
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
List of possible CPU's; AMD Athlon XP 3000+ - AXDA3000DKV4D;
http://www.google.com/search?hl=en&q=Buy+AMD+Athlon+XP%2C+3000%2B+333MHz+CPU&btnG=Search&aq=f&oq=&aqi=#
Hope you find this helpful.
Cheer
Mike
Nov 03, 2009 | Biostar M7VIG 400 Motherboard
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Finding compatible motherboard for new CPU.
Hi kaufam7.
this motherboard will work with your AMD CPU
Biostar M7VIG 400 Socket A+ Athlon 2600
you can check it on this website below
best of luck
magpi
Nov 19, 2008 | Computers & Internet
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
Maldonado223
best processor
AMD Athlon, Athlon XP, Duron, and Sempron processors
200 / 266 / 333MHz front side bus
for further information visit the link
Jun 26, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Emachines220 celron 2.5 gig
I've had 2 emachines t2682s with celeron 2.6ghz procs, go bad. From my research it seems that the PSU goes out and takes the mobo with it. just this week i am updating the latest fatality. Thought i had the fix but new mobo only supports celeron D and P4. Just ordered new proc. Should have changed it all over to AMD like I did with the last one. Good luck finding the right mobo with 2 pata ide sockets. I'm currently trying to use a biostar P4M900-M4 but need to upgrade RAM and CPU. Could have gone with an AMD dual core set-up for same dough. Hope this helps some.
Apr 08, 2008 | E-Machines Athlon XP 2200+ (rb-t2200-c67)
Fastest CPU available for the K7N2G?
Look for socket A processors and ignore the XXXX+ and focus on the XXXXMHz rating (the MoBo's manufacturer's support site will give you the max processor your Board will handle). Since you mention that your MoBo is 4 to 5 years old, you'll probably better serve yourself to replace the MoBo and processor (you'll be able to upgrade to a much better/faster processor by upgrading both, and shouldn't cost that much more), and probably be happier with the result. You may want/need to upgrade your Power supply while you are at it too.
Mar 29, 2008 | MSI K7N2G-L Motherboard
Cpu install
If you go in to the bios you should be able to change the multyplier from x6 to x16.
Failing that try loading optimized default in the bios. :)
Dec 20, 2007 | Intel Motherboard
CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (http://www.digital-daily.com/motherboard/soltek-sl75frv/)
Sep 11, 2007 | Soltek SL-75FRV Motherboard
Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard Logo
160 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
