Question about Samsung LN-R408D 40 in. LCD HDTV
Samsung LN-R408D - No Picture
I have a samsung LN-R408D with just a blank screen. It was connected via HDMI to an amplifier.
TV powers up, and LCD panel turns greyish, so i assume power is OK, but no Image. Thought it was the HDMI port, so conneted a DVD player via RCA cable (Yellow / Red / White). DVD Audio can be heard through the TV speakers but no picture. Samsung troubleshooting talks about maybe contrast / brightness turned down to minimum by error, but even when i press the menu button on remote, i dont get anything on the screen.
So looks like a bad panel or board or something. Please help.
  • 1 more comment
  • marzoid Feb 26, 2008
    Thanks
    Have opened up the back of the TV, and will reseat the cable. Looking at the mainboard, the part # i see is BN41-00567E. Not sure if that's the same main board . Can the main board have 2 part #'s
    I also see a BN41-00562A (???) and BN41-00521B (power supply) and BN96-01805A (???)
    Will advise on the outcome after a reseat.
    Note: Looking at the power supply board BN41-00521B i see a capacitor that looks like it has a bulge. It is a Black CapXon 25v 1000uf (CM823). Don't know if this has anything to do with my No picture issue
  • msteinbock Apr 07, 2009
    I have a Samsung LN-R408D LCD TV that has a bad Thermistor (KL15L5R1). Anyone know of a place to get this repaired? It seems that this is a difficult to get or obsolete part?
  • wags7879 May 11, 2010
    I have the exact same problem. Did you get yours working again?
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
  • 5 more comments
  • OZara Nov 06, 2010
    After 4 years this did the same thing. It was on then turned off a couple of times while watching TV, then a few days later no picture only sound no menu no other sources for picture. (I paid too much for this for it just to last 4yrs!)
    I've been reading about changing the T-CON chip and I didn't wanna pay $120 for the part when I can get a 50" for around $650.
    Then I saw this and ---- Yup this worked for me too. I used a wire to by-pass the fuse and it worked, It was a little difficult to work in such a small opening, I tried soldering from the connector to the C13 but ending up un-soldering the connector from the board. so I connecting the wire from one end of the fuse to C13.
    Lets see how long this last. No more Samsung after this! ( unless its free or they send me a T-CON board for freeeee!)
    Thanks!
  • vektoralian Dec 09, 2010
    I would HIGHLY recommend a fuse instead of a wire. Why did it blow? Start low and increase amp rating until it is stable. I followed your instructions but also included a 2A fuse after a 1A blew. Be safe.
  • bpolo215 Jan 17, 2011
    I am getting ready to try this fix, Man is this a extremely small area. I can't tell if the jumper is soldered the first or second VIM section point from the right and what gauge is that wire?
    In response to "vektoralian" would any 3A-32v fuse work? ( ie glass tube or car fuse) I guess I guess I better get my big magnifying glass and small very sharp soldering iron out as this is going to be a challenge.
  • Trey DuVal Apr 21, 2011
    I just fixed my tv!! Thank you so much
  • smbaby Apr 21, 2011
    I can't remember now which pin it was, but it was easy to figure out by following the trace from the fuse. You might be able to solder to the connector side of the fuse as well, but I didn't want to dislodge it. When I did the fix, I removed the RF shield which gave much easier access. Not sure of the wire gage. Just grabbed the smallest I had. I agree that the "right" thing to do would be to use a fuse, but be careful not to let it short against anything else.
    I'm very pleased that some folks have gotten use out of the hack. Credit to ZORBUS and "Steve's" for the idea. Sometimes the manufacturer doesn't properly account for component aging, inrush, etc when they size a fuse.
    My Mom's TV has worked fine since the repair.
    Watch out for the HV!
  • bpolo215 Sep 07, 2011
    I did this 8 months ago and it worked great all this time, the picture is great without a hitch. The problem now is for some reason the sound went after all this time, Is there another trick fir this or is it time to let this old girl go? (a shame because the picture is really working great now)
  • 132 Answers
That P type fuse is a 3 amp 32v fuse.
http://www.wehong.com/news_editor/UploadFile/20093418384247.pdf
Posted on Oct 09, 2009
I'm having the same problem. I put a new t-con board on but that didn't fix it. What else should I try?
Posted on Dec 08, 2011
    New Friend:
This worked like a charm!!!!! replaced two power supply caps that were leaking and put in the jumper wire - TV fired right up and has an excellent picture. My friend gave me this broken TV for free!!!!
Posted on Dec 23, 2016
    New Friend:
What pin do you solder to on VIN connector
Posted on Dec 12, 2015
  • smbaby Jan 18, 2016
    Don't remember the pin number, but the fuse is the part with the P on it (labeled "CP" in on the board). You should be able to follow the trace from the fuse to the connector and see which pin to use. You are basically just bypassing this fuse. (It would be better to replace it, but that requires some fine soldering). My mom's TV is still working with this fix as of Jan 2016.
    Sergeant:
  • 395 Answers
Reseat the LVDS cable inside the unit. this is the cable from the main board to the panel. if the problem is still there then replace the main board 1st, part # BN94-00629F. if the problem is still there then the panel is bad, part # BN07-00245A. if you are not familar with TV repair have a tech repair this for you, if it is under warranty call the manufacturer for nearest repair place.
Posted on Feb 26, 2008
  • Robert Johnson Feb 27, 2008
    yes replace that cap it will cause no power condition
Bent hdmi port for sansung tv
no, the board it is on is sold as a unit---I have seen several techs try to replace the socket---there are some sites on the internet that stock by model number all the boards Google Samsung boards/parts.
The only other option I see is connect the set via another input like component--that connector and the board are history.
Oct 22, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Samsung LN-R408D no display
The part labeled cp with a p on it has a black burn mark in the middle of it on mine!
Aug 19, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Samsung LN-R408D 40 in. no picture
I'm willing to bet you have a backlight problem. Turn on the TV, take bright flashlight and shine it on the screen. Do you see the faint image???
Jul 28, 2012 | Samsung LN-R408D 40 in. LCD HDTV
Samsung LCD TV Screen is very dark but still shows picture
You either have a bad Power Supply or a bad Main bd. Worst case can be the inverters on the Panel have gone bad in which case the Panel needs to be replaced.
Jul 06, 2009 | Televison & Video
How do I remove the back panel from a samsung LN-408D? I have removed all of the screws, but the panel doesn't seem to come off.
Samsung LCD TVs has 12-16 screws that need to be removed before taking back off.
Dont forget the screws that hold the connection panel (SCART, HDMI, etc) and the bottom screws that hold the stand. These are screws i missed when i first opened my Samsung TV.
Good luck !
Jun 29, 2009 | Samsung LN-R408D 40 in. LCD HDTV
Gray screen
Try unhooking the LVDS cable from the controller board and see if it does the same thing. If so you need to replace the LCD panel.
Oct 27, 2008 | Samsung LN-R408D 40 in. LCD HDTV
Broken HDMI port
its a soldering job and you need to remove the board from the tv, not easy and not for the faint of heart
Apr 30, 2008 | Samsung LN-R408D 40 in. LCD HDTV
LN-R408D Samsung LCD flat screen TV
they must try to repair the smps [puff capacitors]first.then try a master reset thru the service mode.if these steps do mot solve the problem replace the t-con board on lcd panel.
Mar 26, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Feb 18, 2008 | Televison & Video
Samsung LN-R408D 40 in. LCD HDTV Logo
5,288 people viewed this question
Jerry Greenberg
Jerry Greenberg
