Question about Brother MFC-210C All-In-One Printer
Reattach flatcable The read out screen had came loose on my printer,and I took apart the front panel of the printer. and when I was putting the screen back into its holder ,I pulled the flatcable loose.How do you reattach ,to get the screen to read out again?
  • 832 Answers
At which side did you loose the flatcable? When it is done at the glassside you have cut off the flatcable, then there is no fixing anymore, sorry.
In case it is on the main board side simply plugin the cable to its position...;-)
Posted on Feb 26, 2008
Reattached tub, but spin cycle doesn't work
the belt might have come off of the tub take it back apart and look underneath and see if the drive belt is loose or on the floor when the tub came loose it probably slipped the belt off before stopping.
Dec 12, 2007 | GE Profile Prodigy WPSE4200A
I TOOK THE 2 SCREWS OFF OF THE DOOR LOCK, THINKING I WAS REMOVING THE FRONT PANEL OF MY GE WSSH300GWW
First unplug the machine. If you remove the bottom panel you can reach all the way to the door lock position and should be able to reattach it easily. Why if i may ask were you trying to remove the panel?
Jan 27, 2013 | General Electric WSSH300GWW 3.5 Cu. Ft....
I have jammed a bostitch t5 staple gun and would like to know how to unjam it
if you take the pins out that hold the front off it will allow you to get at the jammed staple but be careful how every thing comes apart it will not work if shims and washers are not replaced right
Mar 14, 2011 | Aerobie Arrow Staplebrad Gun T50pbn
Have 42PX12XC red vertical i inch lines on both sides. whats wrong ? can i fix this myself ?
The lines on the screen show that there is a poor connection with
the flatcable on the controller board.
Ok lay your flatscreen on a table or on your desk.
First remove the backfront cover.
Then you will see the input board frame you've to remove this first.
When you removed the input board you'll see the controller board
LGE PDP 040602
MODEL: 42X2
BOARD: CTR_LVDS
PART NO: 6871QCH038A
LOC NO: 1XXX
The connections you have to check is P105 and P106.
These are the flatcable for the leftside of the screen and
for the rightside of the screen.
Try to keep the input board up to 45¤ and leave the wires connected.
Now put the power on and see for your self when you push on
the flatcable you will see the lines disapear and the screen show
normal asual.
This indicate that the soldering points are bad to resolve this you can try to resolder the soldering points or you replace a new controller board this part you can find it here.
http://flattvparts.co.uk/index.php?main_page=product_info&products_id=2592
I hope this will help you out.
I had the same problem and resolved by myself so its easy to do
and I'm sure you can do it too!
Best regards : Henk®uskita©2010.
Dec 28, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Hp not turning on laptop
you haven't got the TFT cable plugged in correctly
Jul 25, 2009 | Computers & Internet
Monitor goes black when cable attached
Looks like a "mechanical" problem (cold solder point possible or bad electrical contact)
Aug 04, 2017 | Samsung SyncMaster 173S (Black) 17 in....
Whenever I turn it on theres just a blue screen and I can't get it to record
It took me a while to figure this one out but I finally did and mine is back to working perfectly. The problem: The Play option worked fine but the camera did not. When turned to camera mode the blue canon screen would come up and then freeze. The only way to turn it off was to remove the battery.
The fix: I was brave enough to take the entire outer shell off the camera. On the main board, underneath the screen/battery side, all the different parts are connected together. There is a single connector from the lens that had come out of its port. The ribbon connector must have somehow been shaken out of the port at some point. With needle nose pliers I carefully fit the ribbon connector back into the port. I carefully reattached the outer shell and everything was back working!
I will warn you that this task takes some time due to many many screws. It's a lot better than sending it off for hundreds of dollars though.
Oct 12, 2008 | Canon Elura 100 Mini DV Digital Camcorder
No read out on screen
you have to dismantle the board (backside "inside" the scanner). Check if you have disconnected the flatcable between the display and the circuit board.
The foil that you have pulled of is OUTSIDE (where you push the buttons), i guess. This has nothing to do with the display reading.
There could be the dimmer set back to light reading, too. This has to be set by help of the menu button (see manual).
Feb 25, 2008 | Brother MFC 210C All-In-One InkJet Printer
Init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Sep 13, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-210C All-In-One Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
