Question about HP Pavilion Dv1000t (ED338AV) PC Notebook
DV1000T chip PC87541V-VPC is extremly oveheating and freeze keybord
I have a problem exactly as i wrote in topic. When i start notebook it works fine for about 1 minut. But after that time it freeze the keybord but rest is still runing.
How do i know that this chip is overheating? because i took off the bottom of the case and touched this chip. My finges was nearly fried. And computer worked only ONE minut. Processor was cold but this chip was burning hot.
How can I solve this problem? Maybe some of the SMD elements is bad? But wich?
Look at this photo [click to enlarge]
[url=http://www.vpx.pl/grafika,116674.html][IMG]http://www.vpx.pl/up/20080226/sr11667487188e3f6185e00360616932cdf2214399780.jpg[/IMG][/url]
  • 3 more comments
  • hyb_rid Feb 26, 2008
  • hyb_rid Feb 27, 2008
    I've already cleaned the electronic and heatsink of this notebook.
    And i repeat, processor is COLD. The other chip is overheating.
    Look at this picture, It has no heatsink on it.
    And i think that something is wierd. When I plug power supply adaptor, this chips is getting hoter even without turning on the notebook!
    The same problem is when running on batery.
    One more thing, voltage in a keybord pins is 1,75v.
  • darkangel13 Apr 11, 2009
    gateway chip PC87541V-VPC is extremly oveheating
    hi i have the same problem. if you can see the chip maybe it's broken o burn. the mine is. i am finding the datasheet for to know works, and disable the power the this chip and maybe you computer run
I do repair laptop for 5 yrs and I have a lot of problem with acer motherboard overheating with this chips 87541V like aspire 5580, aspire 3680 and other model...
Im sorry to those who buy ACER good luck... Acer laptop is good within one year before warranty expire.
Posted on Nov 10, 2008
  • jackspratb Oct 28, 2010
    Are these i/o chips a straight drop in replacement or do they need to be pre-programmed?
Gateway chip PC87541V-VPC is extremly oveheating
hi try this: put on disipador like core has.
Posted on Apr 11, 2009
Change the chip , it maybe on another Mobo use a Heatgun
Posted on Apr 22, 2010
    Scholar:
  • 181 Answers
try booting without the ac adapter, just the battery. If you have a meter, try to determine if the ac adapter output is what it should be.
Sorry I couldn't be more help. Let me know how it works running off the battery only.
Posted on Feb 27, 2008
  • 28 Answers
One way to stop the computer from overheating, is to completely strip it and clean out all of the dust. Typically it is dust in the heatsink the overheats the processor, resulting in the problem you are currently having. If you decide to take the heatsick off of the processor, you should wipe all of the heat grease off the processor and heatsink then reapply new heat grease. Make sure you only apply a very thin layer onto the processor.
Keybord key not functioning properly
go to control panel and regional setting and change keyboard to english
Nov 16, 2012 | Computers & Internet
Dell latitude e6400 freeze
might your memory is low or need replacement.
Jul 19, 2012 | Dell Latitude E6400 Notebook
Apple MacBook "Core Duo" 1.83 Problems, boot up takes 4-5 minutes, cannot stream video or run disk heavy programs(iTunes) while running others. Stops freezes up may or may not start backup, some times it...
Yes, take it in. You got logic board problems with the video or processing chip, but first back up all your files and try installing a new hard drive with new OS to see if that clears things up for ya. Thats the cheaper way to go first.
Sep 09, 2010 | Apple MacBook Mac Notebook
My girlfriend got a dell inspirion mini 10 for christmas and we've been using it's webcam and if she doesn't have the power cable in the computer it runs fine, but when she plugs the power cable into the...
Thats just your computer ending the process of skype.
As for the pc shutting down automaticly it can be that its oveheating!!
On my Dell Inspiron 2200 I get the Blue Screen every 2 hours and I dont mind.
Might be bad memory
Dec 28, 2009 | Dell Inspiron Mini 10 Notebook
Ibook g4 freezes and airport problem
have you gone into airport utility?
are you using an airport extreme? if so, reset it.
then delete the current wireless network, and try setting up a new one in airport utility.
Feb 16, 2009 | Apple iBook G4 Mac Notebook
M40x sometimes freez on logo
Sometimes viruses can trigger slow start ups. Try running your virus scan. also, you should make sure that your memory is working correctly. When you have a memory stick that has failed, its hard to tell if you have over 2 gigs of mem installed but, when you start it up, it will struggle during the process.
Jan 28, 2009 | Toshiba Satellite M45-S165 Notebook
Compaq presario R3000 Laptop power and fan problems
Your machine is overheating. Try cleaning the vents with a can of compressed air and making sure the heat sync is free of dust. If that doesn't work, you may need to replace the fans.
Jun 07, 2008 | Compaq Presario R3000 Notebook
Acer Aspire 5101after booting its freez
reboot it to an ealyear day when your usb worked
Jan 15, 2008 | Intel D865GBF Motherboard
Computer freezes...but not in the normal manner
The intel chip that is under the touch pad is the culprit. If you open the laptop by removing the keyboard, you will notice the chip just under the cover. i have tried putting pressure on it with an eraser and got some results. Mackay Rigava
Oct 12, 2007 | Compaq NX6110 TFT XGA Notebook
HP Pavilion Dv1000t (ED338AV) PC Notebook Logo
1,666 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
