Question about Maytag Neptune MAH5500B Front Load Washer
Neptune front loading washer
Our son started a wash, forgot something, hit stop, opened the door, and now the door will not fully latch at the top. So we sit with water in the machine, but door won't latch. Help.
We solved our problem by hiring a local appliance repair person and he handled it.
I have asked for a refund because we didn't get to use the service. Please respond. Thanks.
Posted on Feb 27, 2008
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune; power on but won't start to wash
does the "door locked" light ever come on? if it does, you may be able to get away with just the wax motor in the latch assy. Usually this call requires a control board as well. A bad board can be confirmed by looking for a burned resistor on the board itself(in the console) remove the screws along the top of the console and rock the console forward. The back will remain in place with some components attached to it. there also should be a tech sheet stuck in there with some diagnostic tests on it
Sep 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer is making a buzzing sound and does not start making sound from where latch is will not release the door its staying locked . the code its showing is FL and DO.
if you open the dispenser door on top of the washer, and feel around the front you should find a little green ripcord. pull on the cord until the door releases. most likely the wax motor in your door latch is fried.
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do I open the top of my front load washer (Neptune Mod. MAH3
there 3 screws on the back u take off but to take door latch off u dont need top off u open your door take the spring off the front of your boot then remove the screws from door latch reach back there behind boot unplug put new in and put back togather
Apr 08, 2009 | Maytag MAH6700AWW Neptune Front-Load...
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Error Code LO
latch open it means your latch on your door is not connecting It happened to me when I switch the door to open the other way your washer wont start or will stop mid cycle if the connection isn't made it is simple to fish hopefully you haven't already paid for someone to come to fix it :)
Apr 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door won't open on my front loading maytag washer
Try unplugging machine and then plugging back in see if that resets it. Also if you still cant get it unlocked there is a emergency latch release. Remove the 4 phillips head screws holding dispenser trim/lid. Now look in in front of (closest to door) now look for what appears to be a weed eater line (it should be green) pull gently and it should release door. Hope this helps get to your sons socks.
Jan 20, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
