Question about Dryers
Whirlpool Model LG5801XK Gas clothes dryer
This unit burner will not light. The igniter comes on & stays on for about 5 seconds & then goes out. The gas valve does not open (it appears) The timer has been replaced & no help, but the first time it was started after the timer replaced the burner did come on for a minute or so. Any help appreciated
    President:
  • Dryers Master
  • 2,651 Answers
First ck gas to unit, next is ck the coils on the burner valve right, there(i just looked up and this is an older unit) set of coils is about $85, the entire burner valve including coils and new ignitor is about $135.that would be my bet the whole thing but is it worth it putting 135 into the dryer
Posted on Feb 27, 2008
Whirlpool wgd9400swo. Gas clothes dryer The burner only stays lit for 1 minute the new goes out, tries to re-light but can't seem to
The limit switch is bad. most likely or the igniter. Does it give off a gas smell? If it is propane you can really smell it. But Natural Gas You may not.
Nov 08, 2016 | Whirlpool Dryers
Igniter starts to glow for 3-5 sec while making noise every minute or so
Check the thermocouple it is going bad or already has and that is why the gas valve is not staying open.
Jul 08, 2017 | Whirlpool GGW9200L Gas Dryer
I have a whirlpool gas dryer model#LG5801XKGO.
Whirlpools are great. There is a flame sensor near the igniter, it gets dusty and can't sense the flame. Carefully wipe it off, without bumping the igniter, it's super delicate. Sometimes the sensor can be removed for cleaning, just held in place by a little screw.
Nov 26, 2013 | Whirlpool Dryers
Lgr5620kq1 dryer,heat comes on but does not stay on,
If you find that the dryer initially lights, then goes out and the igniter coil glows, then also goes out, it's the valve solenoid coil, about $25.
There is a temperature limit switch as well. This usually either fails entirely (no heat at all) or operates the burner out of the normal range (often showing up as clothes taking too long to dry).
A clogged dryer vent will cause problems with heat cycling, too.
Apr 07, 2010 | Whirlpool LGR5636L Gas Dryer
Burner ignites for 4to 5 seconds then goes to reset
it is a gas dryer if the igniter is not working properly contact a service man Gas is one thing you do not fool with re igniters
Dec 17, 2009 | Whirlpool LGR5636L Gas Dryer
I have a maytag model mgd9316aww gas clothes
sound's like silanoild's on gas valve not opening to let gas in.
Nov 15, 2009 | Juicers
Whirlpool gas dryer rotates, gas ignites but goes out, won't reig
coils on the gas valve, especially the single coils that whirlpool uses, break down after use. They may ohm out good when cold and the burner may light 1, 2, or 3 times, then you get ignition failure. Coils are bad. Hint when replacing coils. the front coil which has 3 terminals has a metal sleeve inside the coil. Make sure that sleeve stays with the valve. It can get stuck in the old coil and thrown away. Good luck
The Squirrel
Mar 26, 2009 | Dryers
Whirlpool Gas dryer ignites when I first turn it on and gets hot but won't stay hot or ignite again.
replace the 2 coils on gas valve after warm up they fail to open valve to reignite burner
Nov 03, 2008 | Whirlpool LGQ8611L Gas Dryer
Whirlpool LGR4634JQ1
Check for a restricted vent. Clean vent and check for kinks. Make sure lint screen is clean. If you do-not have good airflow due to a restriction, the burner will not stay on. It's a safety thing.
Nov 18, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
268 people viewed this question
Top Dryers Experts
