Question about Brother IntelliFAX 1270E Plain Paper Fax
Can recieve well, sends all black
The machine can recieve fax, but only can send a completely black page.
    Scholar:
  • 159 Answers
The scanner is not receiving light. That is either because paper is covering the scanner, or the scanner light source is not working. In this case, make sure the connections are in place, if so, replace the scanner.
Posted on Feb 27, 2008
I am getting a white line down the entire page
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
Apr 26, 2010 | Canon FaxPhone L75 Plain Paper Laser
When sending fax on recievers end all the writing is downsized
Try sending a fax to someone else and see if it does the same thing.!
If your sending a 14" page to someone who only has 11" paper in the machine....the machine can only do one of 2 things...reduce the 14" page to fit on 11" paper "OR" print 11" on 1 page then the 3" on the second page....this setting is controlled by the rxing machine.
Apr 16, 2010 | Office Equipment & Supplies
We have a HP 1050 fax machine. Usually when we send something, it displays send ECM and the number of pages. Occasionally it displays send G3 and the number of pages. I can't find anywhere in the user...
this is just the transition speed and line condition and you dont have to worry about it , the machine will give you an error code if the faxes dont go through alturnativly contact the reciever of the fax to check that they have recieved it
G3 means poor line condition
Apr 09, 2010 | HP 1050 Plain Paper Inkjet Fax
Black pages on every fax I send
Is sounds like your exposure lamp is not coming on, put an original in the machine and make a copy, if you look where the original is coming out, you should be able to see a light illuminatig the original so the scanner can read the image. If this lamp is not coming on you will get a very dark to black image.
If it is just locked up is may be as easy as this. Turn off and unplug the machine for a couple of minutes, reconnect and power up the machine, make a copy. as the machins uses the same parts to copy you should see the result of your efforts.
If the copy look good, try a test fax to someone, and call them for confirmation.
If this doesn't fix the problem, then I suspect the exposure lamp unit has failed.
Hope this is of some help.
Apr 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Reciever gets a black page
It sounds like you have a bad scanner unit.
Nov 10, 2008 | Office Equipment & Supplies
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Recipient receives a black page
What happens when you make a copy on your machine?
Dec 11, 2007 | Sharp UX 300 Plain Paper Thermal transfer...
Brother IntelliFAX 1270E Plain Paper Fax Logo
172 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
