Question about Epson TM-U295 Matrix Printer
Printing I need to push the Print bottom twice to get the number on the paper. How do I set it up so is only one punch os the Print bottom??
    Brigadier General:
  • 3,614 Answers
You mean you want to see or put a page number on the document you're printing?
Posted on Feb 26, 2008
How can I print both side of the paper in canon MF4400
Chooseproperties from the Print dialog. Properties may be indicated as Advanced,depending on the application software. Now Click the Page Setup tab. In thePrinting Type section selects 'Duplex Printing'.
When a media type other than Plain Paper, Photo Paper plus Double Sided, orPostcard is selected in the Media Type menu, duplex printing cannot beperformed. Now state Staple Side and the steps are:
1. The printer analyzes the Orientation and Page Layout settings, andautomatically selects the best staple position.
2. Click the Staple Side drop-down arrow and select the setting. If you want tochange the setting, select another value from the list.
3. If necessary, click Specify Margin... and set the Margin width.
Finally when the setting is completed, click the OK button at the bottom of thewindow. You will be prompted, while printing, to remove the printed page andreload it in the ASF. Needy on the number of pages to print, you will need torepeat step 7 until all pages have printed.
May 07, 2011 | Office Equipment & Supplies
Can not get printer to print information that on top to be copy on bottom of same page.
  1. Select 'Properties' from the Print dialog.
    Note: Properties may be indicated as Advanced, depending on the application software.
  2. Click the Page Setup tab.
  3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'.
  4. Select 'Duplex Printing'.
    Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed.
  5. Specify Staple Side.
    1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position.
    2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list.
  6. When the setting is completed, click the OK button at the bottom of the window.
    Note:
    If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
    The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
    If Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
    The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages.
  7. You will be prompted, while printing, to remove the printed page and reload it in the ASF.
  8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed.
Feb 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma iP 6600D printing problem.. went to print a scanned document .... paper began to feed in askew from autopaper feeder . Printing process stopped. the process was repeated a couple more times...
To fix the paper feed problem, Clean / rub each roller with a damp cloth with a dab of detergent.
Check for paper residue , especially near the paper empty flag,
Then reset the printer:
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0?. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Canon Pixma iP6000D InkJet Photo Printer
I have a Xerox 7655 printer and I am trying to use the direct print tabs. After downloading the template and following the instructions exactly, they are printing upside down and backwards. Can someone...
You may need to change the driver. I have seen different issues with machins printing tabs, that changing the print driver will solve. Most of the tab issues are when the driver is a PCL 5 or PCL 6 driver. Switching to a PS driver frequently helps resolve those issues.
The newest drivers would be located on Xerox.com. Go to the home page, select Drivers and downloads, then enter your model number in the search box, and then select downloads and drivers again and select the newest PS driver and install that. I am pretty sure a new fresh PS driver will resolve your problem.
I am including the setup procedure below, I assume this it the process you followed.
Try a new driver. If that doesn't resolve it, possibly the machine firmware itself will need to be updated to the newest version.
The template is set up to provide centered text in the available tab printing area at each position.
At each printing position click to highlight all the text visible on the sheet. Type in the wording you desire and proceed to the next sheet.
When printing the file ignore the warning about margins.
At The Printer:
1) Load the tabs long edge feed with the smooth edge feeding into the machine. The first tab will be on top towards the front of the printer.
2) Set the paper type to [Pre-cut tabs (106-176gsm).
3) Set the number in sequence using the [up/down] arrows for the number of tabs in the set.
4) Set the paper size to [9x11].
5) Select [Confirm].
At The Workstation:
1) Select [File], [Print] and select your printer from the [Printer Name] drop down.
2) Select the [Pages] radio button and set the page range to 2-6.
3) Select the [Paper/Output] tab.
4) Select the [Select Paper] button.
5) Select [Pre-cut tabs] from the [Type] drop down.
6) Set the number in sequence using the [up/down] arrows for the number of tabs in the set.
7) Select the [Layout/Watermark] tab.
8) Select [Fit to New Paper size] and select [9x11] from the drop down.
9) Select [Rotated Landscape] from the [Image orientation] drop down.
10) Select [Ok] twice to print the job.
Jan 14, 2010 | Xerox Office Equipment & Supplies
I have a gestetner dsc460 copier. I am going to
okay your machine has the finisher option and punch option? if so when you go to print click file, then print. when your window opens for the printers select the gestetner. then choose properties. then choose printing prfeerences. then choose punch
Dec 31, 2009 | Gestetner DSc460 Copier
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Won't print to right tray
I had this problem and solved it like this:
  1. Right click on printer driver in printers and faxes.
  2. Select printing preferences
  3. Choose paper quality tab
  4. Set paper size (A4 in my case)
  5. Set paper source to printer-auto-select. This is different from the default "Automatically select"
As long as tray 1 is empty, tray 2 should now kick in. Setting the paper source as tray 2 didn't work at all.
You seem to have to set this on each client computer though - even if you are sharing the printer over a network (4200n).
Sep 23, 2008 | HP LaserJet 4200 Printer
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
Epson TM-U295 Matrix Printer Logo
79 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
