Question about Linksys EtherFast Cable/DSL Router
BEFSR81 admin problem when enabled uPNP
Since we got a PS3 my son requests that I enable uPNP on our Linksys BEFSR81 router. I enable uPNP and then save settings and after it has saved then I try to get back into administration on the router and can't. It won't take the password, whether I leave it at the default or set my own, I can't get past the login box. We can go ahead and use the router as it works fine, but I can't make any administrative changes unless I reset the router and clear it out. Help, what am I doing wrong?
Ver 3 with firmware 2.51.3
  • 1 more comment
  • bsimpson Feb 26, 2008
    Yes I can reset the router and then get back in again, but when I do that uPNP is off by default. If I leave uPNP off then all is fine. Once I turn uPNP on then I can't log in again.
  • bsimpson Mar 02, 2008
    What? I don't understand what you are trying to say?
    I don't need an "expart" to configure my router. I can configure everything I need on my router as long as i don't enable uPNP. When I enable uPNP on my router I can't get back into my router to change anything else. Did you actually read my posts??? Look at your first answer and then look at my first post again and you will see that I already tried your suggestion.
    I think the problem maybe lies with network services on the PC that I am trying to access the router with.
    BTW Only need to hold reset for 30 seconds, not 3 minutes. Also default logon is
    user: (blank)
    pass: admin
  • dienerd Jun 09, 2008
    bsimpson described the problem perfectly. I'm trying to setup a Panasonic webcam which requires upnp. When I enable upnp, I'm unable to login to the router - unless I hard-reset the router. I've upgraded the BEFSR81 to the latest version of firmware, but still have the problem. Does anyone have a solution to this?
I actually FOUND the solution at the linksys community forum site. It's weird, and I quote [kiefmoon], "I beat my head against this issue for the past few months, for the same reason as you: I'd built out a Windows Home Server, which can configure a home router automatically via UPnP, so I happily enabled it on the router, only to be locked out of the web-based configuration page.
Good news though! I just figured out the cause of the issue -- and it's really dumb:
You turn on UPnP on the Passwords tab, right? Well, if you look around on that page, you'll notice that, along with the option to enable UPnP, there are two password fields filled with asterisks. I think most people would assume that if they don't change anything in those fields, then click Apply, that the password has not been changed. And they'd be wrong. I don't know what the password gets changed to at that point, but it's not "admin".
...So the fix is: when you enable UPnP, do yourself a favor and enter a password in those fields (ideally something sronger than "admin" ). That way, you'll actually know what the password is when you get prompted for it."
Posted on Jun 16, 2008
  • 813 Answers
In the router has one rest pin just press it for 3 min then after try to logged in but remind u have to configer agin
defolt ip is 192.168.1.1
user: admin
pass:admin
try it
Posted on Feb 26, 2008
  • sandip panchal
    sandip panchal Feb 27, 2008
    now isthere happen now u have to go with expart its will format your router & reconfuger it then your problem will be solved
    good day
MY upnp on the router is enable but when i do connection test on the playstation it says that upnp is not avaible. can you help me
Once you have enabled UPNP on your router and saved the change, restart your router and your PS3, then try. That should get them on the same page and the PS3 to read that UPNP is enabled.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Need to change NAT type from moderate to open. possible upnp problem?
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://192.168.1.1 ( Default password is admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54gs changing upnp settings
Hi, you can enable UPnP on a Linksys WRT54GS router by logging in and then clicking on the Administration tab. The first sub-tab is Management, and at the bottom of that page there are buttons to enable or disable UPnP. Click Enable and then click Save Settings at the bottom of the screen.
Jul 21, 2010 | Zyxel P660HW-D1 Router
Hello i am trying to connect to me friend on xbox live with a WRT54GS linksys router and i unchecked the nat filter and the upnp is enabled but i still cant connect
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 20, 2010 | Linksys Wireless-G WRT54G Router...
How do I change the Upnp settings on my router?
Linksys Routers are one of the best Home wireless routers. it has good security feature and better wireless length. To change the Upnp setting on your router
follow these steps
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1).Press Enter.
Step 2 The default username is admin (all lowercase) and the default password is blank (nothing). Click OK.
Step 3 Click the Tools tab then click Misc. to the left.
Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wirelessrouter, or select Disabled using the radio buttons to disable it.
Step 5 Click Apply and then click Continue to save the new settings.
Read more for setup linksys router
How To Setup Linksys Wireless Router In 5 Min Fixingblog com
Jun 07, 2008 | Linksys Wireless-G WRT54G Router
Hi...unable to connect to ps3 using siemans gigaset se587 wireless router
hi there,
first you need to make sure u can access your wireless router with no problems and the wireless is turned on for your ps-3...then u need to forward some ports...
Turn on PS3 and goto Settings, Network Settings.
Select Internet Connections. If it asks you want to be disconnected select Yes. Select EASY. Select wireless
Select SCAN this will take a few minutes. The PS3 should find your router and already have the SSID# so just type in your WEP key. Select save and then wait a couple of minutes then select test. It should hook up.
If it hooks up with NAT3 then you will have to enable UPnP on you router. type in http://192.168.1.1 on your computers web browser.
username: admin
password: admin
Click on the advanced tab and then on Universal plug n play and then make sure both check boxes are marked.
Then on the PS3 make sure the UPnP is enabled also in the network settings.
This should give you network and NAT2.
please try this link for port forwarding help:-
http://www.portforward.com/english/routers/port_forwarding/Siemens/GigasetSE587/PS3_NAT_Type_3_to_2.htm
Apr 20, 2008 | Computers & Internet
Ps3's working online. Laptop not working online. HELP!!
the network of your ps3 and loptop did not match try to use other IP address?
Feb 06, 2008 | Sony Playstation 3 (PS3) Console
Slingbox
Access your router interface page by typing http://192.168.1.1 in the address bar of your browser, the login is Admin password is admin. Click on the "Administration" button on the top right. On the bottom you will see the option to enable UPnP. enable it there and you should be good to go.
Jan 09, 2008 | Linksys Wireless-G WRT54GS Router...
AOL Broadband Cable
The following routers are the only models that support the AOL Broadband Cable service. Note: All Linksys routers support AOL DSL connections due to the standard PPPoE login and authentication connection type used with that service. Please be sure to check the version number of your router (which can be found on the underside label). Only the specific models and versions listed here are supported by AOL Cable: * BEFW11S4 * BEFW11S4 v2, v3, and v3.2 * BEFSR41 * BEFSR41 v2 * BEFSR11 * BEFSRU31 * BEFSR81 * BEFSR81 v2 * HPRO200 (Available from AOL only at this time) You must Enable the "AOL Parental Controls" option located in the Security tab of the web-based Setup utility pages of these routers in order to get a connection using AOL Cable. You may access the utility by visiting http://192.168.1.1 in a web browser and by logging in using the router's password (by default, the password is admin).
Feb 16, 2006 | Linksys HomeLink Phoneline (HPRO200)...
Linksys EtherFast Cable/DSL Router Logo
1,456 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
