Indersit w83 will not work
The program dial just keeps on turning, I have been told that it needs resetting, any help would be appreciated
  • 67 Answers
To reste your timer you must put it on one of the black dots press the stert button and you will see the door LED flash rapidly now the timer is reset. But if after doing this it cotinues to click round thet would indicate a fault poss a pump or blockage, brushes in your motor or a motor fault, heater or control module. There are far too many posssibilities to go through them all. Good luck
Posted on Mar 03, 2008
Bosch washing machine 1200 express wont work F63 fault.How can we correct and reset
Error code F63 indicates an issue with the main PCB - a control board failure.
Try to reset that control board, please follow the steps below:
  1. Turn the program dial to the off or reset position (should be at the 12 o'clock position)
  2. Turn the dial to the 6 o'clock position
  3. Press and hold down on the spin button and simultaneously turn the dial to the 7 o'clock position.
  4. Hold the spin button for around 5 seconds and then release.
  5. Turn the dial to the off position
Hope this helps and good luck!
Apr 30, 2018 | Bosch Washing Machines
How to fixed a error code E43 of washing machine Siemens
This is related to the motor, and may be that the motor needs new brushes the Tacho (feedback mechanism) is broken, wiring or the motor control board. Most likely for a 6-7 year old washing machine is the brushes.
However, after changing them, you still need to reset the machine
  1. Turn off the machine (dial to 0)
  2. Open the door
  3. Turn on the machine on first program
  4. Close the door
  5. Turn off the machine
  6. Turn on the machine on the "six-o-clock" program, which is centrifuge
  7. Press the "option down" button and keep it pressed (This is the button left of the display)
  8. Turn the dial to "seven-o-clock" (empty/pump out program)
  9. Release the "option down" button
  10. Turn of the machine
This should reset the machine, and if everything is allright, it should work. If it does not work after changing the brushes and resetting it, something else is wrong, most likely the motor control board, or if the motor.
Oct 08, 2016 | Siemens Washing Machines
Indesit w83 dial just clicks round, is there a reset button some where
Washed any coins lately? I had a front loading washer and when mine did that it was still under warranty so the service came out and pulled a quarter out of the drain trap. If you not sure where that is contact me
Dec 20, 2013 | Indesit W 83
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
Aug 17, 2012 | Beko Wm & Wma Models Washing Machine Motor...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Stuck on prewash flashing and rinse hold flashing and C9 i have an AEG86800
Try reset. reset it by Holding the Start Button whilst turning the dial through 360 (from Off-2-Off). If not helps first time.Then try it again. --------- If that does not helps then try this procedure as follows:--- Set selector dial to off. Hold in "pre wash" and "soaking" buttons together. Turn the selector dial anti clockwise from "off" to "short spin". Turn the selector dial clockwise to "energy saving" ---------- But if the unit is not getting reset then there is a problem in the motor brushes.The brushes are worn out and that needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | AEG Washing Machines
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Sep 20, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
AEG Lavamat washing macine C9 error code
C9 is a motor fault.
Normally it's worn out carbon brushes so you'll need to check them first.
If worn out or broken, replace them.
Then, you need to erase the code (reset the machine).
To do this, turn the dial to off.
Press and hold together, prewash and soaking buttons.
While holding them, turn the dial 1 click anti clockwise.
Release the buttons.
Turn the dial to off, to any program and back to off.
This should get rid of the C9 code.
It will come back if you don't repair the motor fault.
Dec 10, 2017 | AEG Lavamat 88840 Front Load Washer
Bosch Washing MAchine - E2 error message
Hi.
E2 means uneven balance.
The error code gets reset using the following procedure:
Ensure that the machine door is closed. Turn the dial in the OFF position.
Hold down Start/Pause button and turn the dial anti clockwise at the same time until its position is pointing at the Express (15mins) program.
Hold down Start/Pause button until the e2 message starts flashing (or keep holding for about one minute)
Release the button.
Turn the dial again to the OFF position.
The machine is reset. Select any program.
If the message comes back after selecting program, then there is still a balancing problem. Remove and redistribute load, check floor and ensure machine is at level.
Jan 31, 2009 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
