Question about IBM E54 15" CRT Monitor
Monitor my monitor has no display when i turn on my system unit, but when i press the adjustment menu from monitor it has display, how can i fix it?
Monitor IBm 14r28
Posted on Aug 30, 2008
Monitor IBM 14"
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Adjust time on a procare 400 dinamap
GE Procare 400 DPC-420N Unit turned off. Hold down Menu button while pressing the On button. Press Menu button several times until see a display to the left of the ?min? on the display area. Use + and ? to set time.
Feb 24, 2010 | General Electric Dinamap ProCare Series...
I don't know how to increase the volume
OSD Menu Functions
English
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
automatically.
Source
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
JZKlipper/Mike
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
I don't know how to increase/adjust the volume on my LCM-19v5 computer monitor
OSD Menu Functions
English
keypad button on the control keys. (Note: The OSD menu display will disappear
The LCD monitor has been adjusted to optimal settings before shipment. Adjustments to
automatically.
Source
JZKlipper/Mike
Nov 11, 2009 | Westinghouse Computers & Internet
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
Samsung computer monitor display problem ....display is displaced to left and not centered. what adjustment buttons allows to fix. trying to help someone else. is it part of the menu button or something...
Hello!
Infront or in the side of your monitor there is menu option. either you select the right adjustment by selecting the left or right menu then continue pressing the until it go back to the center. refer to monitor manual for the adjustment menu of the screen.
melnavz
Mar 19, 2008 | Computers & Internet
Screen ajustment
Hi stefan,
You can adjust manually using the OSD (on-screen display) menu of you monitor by pressing menu button. Other monitor OSDs cannot be accessed on single button but some combination of buttons but considering it can be accessed, please look for it. Try also changing the properties at Operating System GUID (graphics user interface display) Control Panel Display or your monitors display monitor application software. Try changing the frequencies and other special features like single screen or wide screen, etc..
Best regards,
Rosener
Jan 30, 2008 | Acer AL1716 17" LCD Monitor
Auto Adjust
I have found a way to stop flickering of auto adjust - press the menu key on your monitor -factory reset-menu button-all settings. That has solved my problem and hope it helps you.
Sep 04, 2007 | ASUS VW192S Monitor
IBM E54 15" CRT Monitor Logo
111 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
