Question about Panasonic DMR-E55 DVD Recorder
Total lock up
Above is linked to panasonic t.v. & pan freeview box via scarts, also have an L.G. video & Toshiba DVD player on same set up again all scart linked. DMR has never worked as intended, told it needs a software reboot. Need it for recording digi off the freeview box and the LG for analogue. Whilst moving for cleaning the other day, mains lead came disconnected, Since then after replacing lead (within seconds) cannot get analogue via t.v. only through vcr. Dmr is locked and will not accept ANYcommands from handset, just goes through constant re-checking. I dont know if theres a disc inside, cannot open it etc. all other leads are fully engaged. How do I sort this ?
  • 185 Answers
The reason your dvd recorder keeps self checking is because there is a faulty regulator on the power board.
I have listed full instructions on how to fix this, but you will need to be able to use a soldering iron and exercise care. Alternatively you may be able to pass the instructions to someone who can repair it for you.
Do not listen to anyone telling you the laser is faulty, DVD drive unit is kaput, it requires firmware, software or any other useless upgrade, or that Panasonic will do it for the price of a small car! It is easy to fix..
I won't repeat the instructions here but if you look at my profile and search my DMR E55 solutions you will find it.
The regulator gets very hot during normal operation and it will eventually fail on all DMR E55s after a couple of years or so.
It was probably on its last legs and when you put the lead back in, you probably didn't disconnect the plug from your power socket and this caused a power surge which has finally killed it.
If you know what you're doing it's an easy fix.
It definitely does not need a software reboot.
I would be reluctant to use it again until it has been fixed because if the regulator overheats further, it could short circuit and cause other components to fail which would make the repair more difficult.
To check to see if there is a disc inside, unplug the unit from the mains, remove the two large silver screws, one on each side, then the three black screws on the back of the lid which can then be easily removed.
Next, remove the four small phillips screws that hold the top cover on the dvd drive. This is a large black plastic cover in the middle of the unit. The cover can then be taken off and disc removed if there is one inside. DO NOT TOUCH ANYTHING ELSE. replace the cover and screws, then repair the unit.
Posted on Feb 29, 2008
  • Palmbeach
    Palmbeach Feb 29, 2008
    Click Here to see my earlier posting with full details on how to fix your DMR E55
Why when playing dvd still receiving tv sound off freeview
The problem is probably in how your audio is liked up. Is the connection from DVD to TV via hdmi, scart, phono, RGB, optical? You need to check that the video link from DVD to TV and the audio link from DVD to TV are the same. Hope this helps.
Aug 26, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I bought a freeview box, My tv has only one scart socket. how do i connect my dvd player to combine with this?
You need a video switch box, that has two video and audio inputs and a video and audio output that connects to the video and audio connections on the scart cable.
Then you can switch between the DVD player or the freeview box.
These devices are available on the Internet, use Google to search for these devices.
Dec 17, 2011 | Televison & Video
My VCR/DVD, freeview box and non digital tv will show prerecorded video and DVD but will not record (or if it has it will not display). Could it be that the set up is not wired up correctly? The freeview...
Unless the Freeview box has two tuners then your going to have problems anyway when you want to record something and watch the non-digital TV at the same time. The solution is simple get another Freeview box (they are around £10 at the moment on E-Buyer.Com) get a box like this:
grubhead_17.jpg Available on Amazon (Scart switching box). This plugs into the TV or you can connect via one of the freeview boxes. Whatever works best.
The VCR has the other Freeview box connected to the second scart. (select AV2 when setting the channel to record and set the box to the channel you want to record) the first scart from the VCR plugs into the above box. When you want to watch press the switch.
By the way if the VCR has PDC on it set it to off, as it no longer works with digital.
Aug 21, 2011 | Televison & Video
Panasonic DMR-BS750EB recording Help needed
I also have the DMR-BS750EB its connected to a panasonic plasma via an hdmi cable and also scart lead so that i can use the tv freeview tuner to record as well and it works just fine if you still have the user manual check the advanced record features for external link or down load the user guide from panasonic. I have had mine since november and had no real issues ... except the ones ive caused from mis interpreting the instructions cheers Alex.
Feb 17, 2010 | Panasonic Televison & Video
I have a Toshiba DVR19DTKB DVD & VHS Recorder with Freeview , A SKY + Box, A Panasonic NV-SD240BL Video cassette recorder, A Samsung PS42B450B1W 42'' Plasma TV, and would like see a diagram of how all...
connect the aerial to the dvd/vcr/freeview combo, connect a scart from that to the tv, from the scart out socket.
you can then connect the sky from the scart marked tv to either the tv direct or to the combo if it has a second scart.
Note. a scart socket with an arrow going into a box is an input, coming out of the boe is an output and a double arrow is a two way scart.
if you use scart 2 on the tv to connect the combo, the combo will recieve a signal from the tv for recording.
Jan 21, 2010 | Televison & Video
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Wharfedale DVDRHD400 Set up Issue
Hi I had the same problem. The answer is to use a scart lead on the freeview box and connect it to the input/output scart on the DVD. Then connect a scart lead from the TV out on the DVD to the TV. You then press Video source on the DVD remote until 'scart' is displayed to pick the freeview channels. Hope that helps
Jun 25, 2007 | Wharfedale DVD-M3 DVD Player
Panasonic DMR-E55 DVD Recorder Logo
244 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
