MAGNAVOX TV MODEL CCT192AT01 FROM DECEMBER/1995
WE HAVE THIS TV W/VCR & NO REMOTE. WE ARE USING A UNIVERSAL REMOTE BUT IT ONLY GOES FROM CHANNEL 3 TO 61 & THEN SAYS "AV INPUT". WE HAVE IT HOOKED UP TO CABLE BUT CANT GET ANY CHANNELS ABOVE 61. WE THINK MAYBE THE TV NEEDS TO RUN THROUGH ALL OF THE CHANNELS AVAILABLE BUT, THE MENU BUTTON ON THE UNIVERSAL REMOTE DOSENT WORK. ANY IDEAS?
    President:
  • 1,779 Answers
You need the original remote for that. Try "remote controls.com" and I believe they should have one. If not, let me know.
Posted on Feb 26, 2008
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
Lost remote
use an universal remote, it comes with manufacturers codes for your TV
Aug 14, 2009 | Philips Magnavox 27MS343S 27" TV
The tv is stuck on channel 3 and i want to change the channel and i have no remote. How do i do it? I have a magnavox tv dvd/vcr vcr recorder model 20mc4304/17
This is hard but understandable. If you cannot change it on the frount of the unit with the channel up and down buttons then you may have to get a universal remote there is no solution or quick fix or any type of factory reset unless you had the remote to get into the menu. good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Philips Magnavox DVD/VCR Dual Player
I have an universal Philips Magnavox remote don't know the model # but I just need to know how to search for the codes. I can't remember how.
These are generic code search instructions for Phillips/Magnavox
Programing with Code Search
1. Manually turn on (TV,VCR,etc.) to be controlled.
2. Press and hold Code Search button until red indicator stays on.
Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.).
The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly ( up to 300 times )
until the device to be controlled changes channel.
The red indicator blinks, then stays lit. If you accidentally
overshoot the code required, press the Channel Down button to
backtrack through the library until the device changes channel.
Pressing Channel Up changes direction to forward again.
Press and release the Mute button to install the code.
If the device you are installing does not have a Channel Up button
use Play(VCR only) or Power, on all other devices.
Jan 03, 2009 | Philips Magnavox Learning Universal Remote
Hello I have a philips universal remote, don't know what model it is I thought all Universal remotes was one Model. Last night I tried using it for my TV to swich from TV to DVD and it just stopped...
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Dec 01, 2008 | Philips Magnavox Learning Universal Remote
Need VCR codes for Magnavox Universal remote model CL034
Nov 26, 2008 | Philips Magnavox Learning Universal Remote
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Remote codes for philips universal
Hope this helps :)
May 14, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
