Question about Zanussi Dishwashers
Zanussi DW 910 TCP Dishwasher
I have been trying to remove the heating element. I have access to the base and have removed the 2 wires connectors. But I cannot see how to seperate the element in the machine from the remaining terminal at the base. I understand that it is held by a screw or nut - but I cannot see how to get to it. Any one know the answer?
  • PetertheRev Feb 26, 2008
    Don't worry - I've managed it myself!!!!!!!!! What a genius.
    Problem Solver:
  • 4 Answers
You might have posted the solution for someone else!
Posted on Mar 07, 2013
Solved it myself - blood, sweat & tears and a great deal of intelligence!!
Posted on Feb 27, 2008
How do I hgain access in order to replace the heater element on my Zanussi dw 905 dishwasher?
www.zanussi.co.uk/Support/
You can get details from the manufacturer .
Jun 23, 2014 | Dishwashers
Tip
How to remove heating element from dishwasher.
1)      First of all, turn the circuit breaker off  to the dishwasher . The circuit breaker is located  inside  your    home's electrical panel.
2)      After the circuit breaker is turned off , open the dishwasher door and carefully pull the lower dish rack out of  the dishwasher.
3) Then look at the  dishwasher's heating element. The heating element is the very thin, circle shaped  tube  located at the base of your dishwasher.
 4)  Then locate the access panel to the dishwasher  which is directly below the door. Properly remove the screws that secure the access panel to the dishwasher with a proper  screwdriver. There are mostly   two screws at the top edge of the access panel. To remove the screws, you will need to open the dishwasher door and remove them from the access panel.
5) Then carefully pull the access panel out  from the dishwasher. You can use a flashlight to locate the wires that are connecting  to the heating element terminals( the two ends of the element).  One wire is connected on each of the terminal ends. The heating element terminals are located at  the rear of the dishwasher.
 6)Slowly pull the wires out  of the heating element terminals. Hold the wire at the metal leads where they connect to the terminals. If you hold  the wires anywhere else, the wire may get cut in between or wire may break out.
7)Then  you will have to remove the nut  located on each terminal .The nut  secures the heating element tight  to the dishwasher . You have to remove the nut. After the nut is removed , then pull the flat washers and the rubber washer from each terminal.
8)      Then carefully open the dishwasher door and  properly un-clip the heating element from the holding  clips in the bottom side of the dishwasher. Then hold  the ends of the heating element and without applying force on any other part slowly pull them straight out of the dishwasher bottom. You will see two rubber grommets. That should come up out with the terminal ends. If the grommets  does not come up with the terminals and remain stuck up in the bottom of the dishwasher, then pull them out of the holes with bit of force.
9)      Now the heating element is out. You can get new replacement element from local appliance part store. You can reinsert the new element in reverse instructions of how you removed the old element.
Good luck.
on Dec 22, 2009 | Kenmore 15899 Built-in Dishwasher
Water temperature is not that hot any more dishes stay dirty after 3rd cycle
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Testing a heating element
Note: Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Use your multitester (aka multimeter) to test the heating element for continuity. Set the device to the ohms
setting x 1. Touch each meter probe to a terminal. You should receive a reading somewhere in between infinity and zero. Because of the variety of makes and models of dishwashers, it is quite difficult to say exactly what the reading should be for each and every possible model. However, if the test you conduct produces a reading of infinite resistance (meter's needle does not move), then that is indicative of a faulty heating element, and you should replace yours. Similarily, if the test you conduct produces a reading of zero resistance (meter's needle moves to the other extreme of the scale), then that is also indicative of a faulty heating element, and you should replace yours.
You do not have to remove the heating element from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Jun 13, 2011 | Dishwashers
How to install zanussi dx6452 heating element
disconnect from electric and water supply. remove drain screen from inside dw , mopp up residual water. remove front feet and plinth cover, and right hand side panel. with machine on its back remove rear foot adjustment shaft.and base cover. disconnect wiring to tube enclosed heater. remove hoses very long nosed pliers help to get clips off/on. extract to righthand side. not much space to work here assemble in reverse. good luck
Jul 21, 2010 | Zanussi Dishwashers
My ASKO D3100 dishwasher has no hot water
Well the heating element in the dishwasher might be faulty or not working properly. To check the heating element - Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you. you need a multimeter to check the heating element....... post comments for more help or information......
Good Luck!!
Mar 27, 2010 | Asko D1776 Built-in Dishwasher
Water not heating therfore dishes not washing or drying right.
Well the water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Please follow the below steps to check the heating element in your dishwasher -
(Note.Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.)
Good Luck!!
Thanks
Mar 02, 2010 | Hotpoint Dishwashers
My Bosch dishwasher is filling and not heating, it drains fine starts filling but never completes a cycle. It is a SHU9956UC
Well you need to check the Heating element, Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Please post comment if you need more help or information........
Good Luck!!
Thanks
Jan 08, 2010 | Bosch SHU9950 Dishwasher
Zanussi zsf6150 water not heating
Hi. i would test the element first. this will be the likely issue.
First, open the door
and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. Test the resistance of the heating element using a multimeter. Set the multimeter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading will be somewhere between infinity and zero. The exact reading differs by manufacturer and model. If the indicator does not move (infinite resistance) or moves to the other extreme of the scale (zero resistance) then the element is damaged and should be replaced.
Sep 02, 2009 | Zanussi 24 in. ZSF6150 Free-standing...
HOW TO REPLACE HEATING ELEMENT
Turn off the electric panel breaker that powers the unit! Check to make certain it is off before proceeding.
You will need to disconnect the Dishwasher (DW) from the electric, water and drain lines and remove it from under the counter in order to be able to access the underside of the DW. There you will find two (2) wires connected to the heating element along with a couple of fasteners that hold it in place. Also check inside the DW for any hold down clamps, etc. on the heating element there.
Once you have removed the connectors and mounting screws, you can then remove the element from the inside of the DW. You will need to "pop" out the grommets that the element passes through from the inside to the underside of the DW, as these keep water from leaking past the elements. Just remove and save those grommets and reinstall them onto the new element and slip it back inside the DW and through the holes in the floor of the unit. Reconnect the wires and re-fasten the screws or clamps that hold the element in place and reinstall the DW back under the counter, reconnecting the water and drain lines and the electric power.
This is a fairly simple and money saving repair for the DIY'er and well worth the time it will take you to perform the replacement. Good luck and hope this helps. Here's a link to the versions of your DW that will show you what it looks like for the parts and placement for your specific unit as I couldn't locate an exact match without the rest of the model number series. Just select yours and look at the diagrams to find the heating element on the inside of the wash tub.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GU980SCG&pop=flush
Jul 28, 2009 | Whirlpool 24 in. GU980SCG Built-in...
I am trying to source a heating element for a zanussi dishwasher zdf221 and information on how to fit this part thanks
if in uk, try currys partmaster mor you local service force dealer. don't know this particular model but should be easy to do. remove back and element is usually held in by 2 7mm nuts. disconnect wires from element, making a note of where they go. there is sometimes also a bracket inside the oven which holds the element up and this also should be removed
Jun 22, 2008 | Zanussi Dishwashers
Dishwashers Logo
112 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
