Question about Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R320
I have a white thin line down the middle of my printouts. It actually has some chalkiness to it. I have cleaned the nozzles and realigned everything, but the line remains. What do you suggest?
Thank you,
Lauren
  • 4 Answers
I had a printer come in for repair for pretty much the same problem, a bit of chalk had fallen in were the paper goes and got fed through under the exit rollers
Not too sure on the R 320 but on a lot of the Epson printers the exit rollers are spring loaded - the are the little rollers just before the head - Have a look and see if you can spot anything, esp in the area were your mark is, if you cannot see anything, does the area look a bit raised?
If there is something there, what you can try is tilt the printer back so to paper in part is near the floor, then try and lift the exit rollers up a bit and hope that the object will drop out the back - be very careful lifting the rollers
Posted on Mar 24, 2008
I'm getting light horizontal lines in my printout.
A cleaning cycle will clear clogged nozzles, but it sounds like you have actual lint on the printhead. Buy an Epson cleaning kit on Ebay. It will come with a special fluid and a
Mar 29, 2014 | Epson Stylus CX9400 Photo Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
New black ink cartridge won't print correctly
It can take some time to get the ink through.
I would suggest do the head clean at least 3 times if you then do a nozzle check and notice improvement then you are on track.
If it does not improve then it has been standing to long and not good news, this I am not willing to be the barer off.
(printer may need to go to heaven)
Keep in mind head cleaning is an ink eater so only do as you need.
Let me know how it goes.
Regards Craig
Feb 03, 2018 | Epson Stylus Photo R320 InkJet Printer
R320 PRINTER CANNOT CLEAN HEAD
manualy clean it using cotton and alcohol
Nov 27, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Jan 12, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Dark red prints with lines throught the picture
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
When you run the nozzel check, do each of the colors print out right, or just the magenta ones?
Oct 28, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
59 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
