Question about Frigidaire PLMV169DC Microwave Oven
Popping and shooting sparks
This is a new microwave. Since it was installed, whenever we turn it on, it pops really loudly, and shoots blue sparks immediately upon hitting the start button, then it works fine. I have had it looked at by a repairman, who stated that he could not find any signs of sparking wiring, and the microwave never popped or sparked at all while he was there. Three days later when I used it again, it popped and shot sparks. Whats up with this?
  • 1 more comment
  • dehlia Feb 29, 2008
    AFter reading your reply, I decided to pay more attention when I was using the microwave, and sure enough the next time I used it, it popped really really bad, and I noticed that I had food cooking on the stove that was steaming pretty good, it had moisture on the microwave, so we may be on to something. I plan on watching it for a while more before I call the manufacturer back. I have until June before the warranty runs out. My question is shouldnt an over the range microwave be designed to handle any mositure that comes from cooking on the stove?
  • jcmoore Apr 09, 2008
    I'm having the exact same problem. Brand new and has sparked from day one (now about a month old). No food or moisture. Sometimes I can open the door to stop, then start it up again and it's fine. It's a zapping noise and light, that happens like clockwork, about every second. It reminds me of a mosquito zapper.
  • Lance99999 May 08, 2009
    Frigidaire PLMV169DC Stainless Steel 1000...
    I had a problem with sparks after condinsation was caught in the microwave. Unit will not heat after this incident.
    Any recommendations?
I had the same sparking problem with a Bosch 5050. Replaced the mica cover after cleaning the cavity, but did not solve the problem,
Any other ideas?
Posted on Jan 29, 2013
Hey I have had the same problem! What's wrong with this microwave!
Posted on Nov 18, 2008
My microwave was "unrepairable" by the local authorized Electrolux service center. Frigidaire is in the process of replacing it. So, if yours sparks, don't assume it's food and moisture.
Posted on Jun 29, 2008
I have a brand new Frigidaire Microwave and it sparks. No food or moisture... The repair people are coming out in the morning to fix the dish washer as well. All new appliances and two of them are broke
Posted on May 22, 2008
  • papabeardan Sep 16, 2010
    we have the exact same problem. Our unit is 3 years old and has done this for quite some time. It definitely only occurs when we have a steaming hot pot on the stove below. Kinda scary.
    Scholar:
  • 135 Answers
Hi There!
Check behind the "Wave Guide Cover" on the inside cavity. There may be moisture or food residue behind it. Should be a cover that is plastic or Mica. Really strange that it's sparking being new. Also check that you use plates without gold or silver trimmings (Crockery or porcelein). This will also cause sparking. Remember that microwaves will always go to the first organic source in its path. The wave guide cover, if soiled, is very close to the tip of the Magnetron and will therefor result in arcing. Good Luck, JUS004
Posted on Feb 26, 2008
  • Justin Smith Feb 29, 2008
    Sure they can handle a lot of steam. It,s the fatty substances in the food that goes up with the steam and clings to the insides.
    Did you find the little cover inside the microwave? It's a cover rectangular in shape and approx. 7cm in length. normally white or cream in colour. Either screws on or clips into position. Behind that you may find the culprit. Also check for burn marks on the door or inside the cavity. Let me know when you find it and problem solved. JUS004
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
Was boiling water and running microwave and a popping sound and blue spark appeared, it still seams to be functioning normally but am worried about what happened???
if you mean you were boiling water in a microwave, then A) that is a dangerous thing to do as any liquid in a microwave is very volatile and B) were the dishes ,containers etc you had in the microwave free of all metal? as that is what would have made the blue spark , when the microwaves connect with metal
Oct 09, 2011 | Frigidaire PLMV169DC Microwave Oven
Frigidaire PLMB209DCB 1200W Microwave. Mfg 2005. Started sparking and loud popping. Scorched cardboard covering. Worth looking at to repair?
No, Your better off buying a new one. Sounds like the Magnetron is acting up and that is the most important and dangerous piece of hardware in the Microwave.
Jun 08, 2011 | Frigidaire GLMV169 Microwave Oven
Microwave made a small popping sound and shut off. Now display says "Door" whenever we try to use it and nothing happens. Do we need to call a repairman again, this is the third failure in 7...
yes the popping sound wad the intermitten door closer sparking it will not work because its not reading the door as been closed advisable to but new mw
Nov 29, 2010 | Microwave Ovens
Problem with GE Microwave Model JES1358WK 02
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
q
May 30, 2009 | GE JES1358 Microwave Oven
Blue sparks from my panasonic over the range microwave
We have blown four... yes 4 over the range microwaves from Panasonic. Are we the only ones having this problem?
Dec 20, 2008 | Frigidaire FMV145K Microwave Oven
Wolf Microwave -- Loud Pop and Sparks
Is it safe to use your microwave if it pops like this all the time randomly... And sometimes lights up in the back like a spark or something???
Nov 19, 2008 | Microwave Ovens
Bright flash inside microwave
try a different brand of popcorn & let me no what happens
May 12, 2008 | GE JES1290 Convection/Microwave Oven
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
1,229 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
