Question about Whirlpool GEW9250P Electric Dryer
Whirlpool gew9250pl1 E6 E7 code
All of a sudden my dryer stopped working. It powers on, but when I hit start it gives multiple beeps. Now I have changed the bulb in the drum and tried to check the thermal fuse. Not sure if it is blown or not, but I can't seem to remove the wires to replace it anyway. In the diagnostics mode when I opened the door there was no beeps or anything. I checked the door switch on the machine control, but to no avail. The E6 comes up in the diagnostic mode and the E7 when I push the cycle speed button. The drum light stays on when the door is closed, indicating a door problem right? Should I bother with the thermal fuse or wrestle with the door switch. My tech sheet isn't real clear in the door switch department.
  • nseaton Feb 27, 2008
    thank you. I was able to get it out, but the way my switch is the wires go directly into this rubber base that seems to be attached to the switch. I tried to pry it off, but I am afraid that I am only damaging the base and will not be able to use it after. Now I am sure if I should just disconnect with the wire harness ( which is proving difficult too) or cut the wires and stripe them to new. I am afraid that the later would do more damage than good.
    President:
  • Whirlpool Master
  • 2,651 Answers
Hehehe good luck deciphering that tech sheet. actually quite helpfull just all over the placeand youd need to know what the hell they are talkin about. but anyway, if your light is not going out, therers the issue, no need to worry about fuse if you cant get door closed.(as you try to push the switch with you finger does it "click" in and out??if not unplug or swithc off breaker, wiht a small screw driver you can pry the switch out(kinda has clips that expand when you push it in, so youll need to compress them to remove. the new switch will push right back in place part num 8283288 it'll come with wires attached no need to use them honestly the few times ive had to replace this switch, for one reason or other as im removing old switch it mysteriously popps out and begins to work, go figure
Posted on Feb 27, 2008
My Aw9770SB toshiba washing machine kept showing this E7 -1 problem how can I fix
Hi Sunny the link below is a toshiba site which you'll find interesting, Please read and scroll down the whole page, I copy and pasted it part for you to read I hope this helps... CHEERS
((if an E6 or E7 error code is displayed on the control panel of your washer-dryer, there is a possibility of wiring disconnection. Please stop use it immediately, remove the plug from the socket and contact the help desk listed below.))
https://www.toshiba.co.jp/tha/info/140204_e.htm
Mar 22, 2016 | Washing Machines
E7
short cycleing is sounds like, could be a bad cap, or alot of diffrent things...its not easy to diagnose on line, your gonna have to call a tech, sorry i couldnt do more 8(
Jun 18, 2013 | Heating & Cooling
Why does the display say"wet" when the clothes are
Try cleaning your moisture sensing strips with windex. Maybe something wet and sticky is on them
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Beep beep beep
Temporary Fix: unplug the dryer or cut its power at the circuit breaker panel, when not in use. If the dryer alerts/alarms are set to silent and the beeping happens when it's not in use, chances are it's the same beeping you hear when you first introduce power to the unit or press start. This may indicate a short affecting the control board. If you need to press start multiple times to get the dryer started, then the control board components are most likely starting to fail.
Apr 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Whirlpool Electric Duet Dryer (GEW9250PL1) will not cylce on when depressing the START Key. I hear a "relay-like" click. In diagnostic mode, when pressing Start I get 1 beep and a cod "08" on the...
It is most likely a blown thermal fuse. There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix. If you don't keep your lint filter cleaned out, you will likely get the overheating problem, causing your thermal fuse to blow.
Apr 06, 2009 | Whirlpool GEW9250P Electric Dryer
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250P Electric Dryer Logo
730 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
