Question about Philips HTS3450 System
Subwoofer is out, speaker and player still look good.
Is it possible to buy a cable to break the 15pin cable into separate digital inputs for another AMP or receiver?
    Sergeant:
    Champion:
  • 319 Answers
No.
Posted on Apr 22, 2008
Speakercraft v10 subwoofer not taking input signals
Does any other speakers work through the channels you are putting the subwoofer through? Reason i ask is could there be a fault with the channel you are using i.e AUX? is your subwoofer connected with Aux cables or is it a speaker cable? If aux cable is there a slight break in the cable?
Jan 04, 2014 | Audio Players & Recorders
Tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
on Aug 13, 2010 | Audio Players & Recorders
THERE IS NO SIGNAL COMING FROM THE SUBWOOFER, IT IS CONNECTED TO A SONY AMPLIFIER IN THE SUBWOOFER JACK, AND CONNECTED TO THE SUBWOOFER IN THE LOW LEVEL INPUT. THE SUBWOOFER IS CONNECTED TO THE MAIN, AND...
With everything connected correctly there could be a couple of possible problems:
1. If your receiver has on screen display capabilities, you may need to turn the subwoofer output "on"
2. If your subwoofer has speaker wire inputs/outputs, you could run speaker wire to it, then to your speakers & test if the subwoofer is working... hence verifying that the receiver has a function to turn the subwoofer output on/off
3. The cable between the subwoofer & receiver could be bad. Try another cable.
Mar 16, 2011 | Audio Players & Recorders
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
Mar 09, 2011 | Yamaha RX-V793
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Dec 16, 2008 | Onkyo TX-SR606 Receiver
Harmon Kardon receiver not compatable connection to subwoofer.
Most subwoofers with RCA type connections are powered subs. They are commonly sold in most hi-fi stores.
Unless your subwoofer has a separate mains lead it will be the wrong type I think.
Dec 07, 2017 | Harman Kardon HKSUB 12 Subwoofer
Connecting subwoofer to receiver.
have u checked that the sub option on the reciver is on?
Jan 06, 2006 | Kenwood 107VR
Philips HTS3450 System Logo
107 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
