Question about HP PSC 1210 All-In-One InkJet Printer
Power surge to usb port when installing cd
My printer wont print,hp 1100/1200 series.I uninstalled software and reinstalled using cd but i get a message in the bottom corner of screen,power surge to usb port,when i diconnect and re connect,the same message appears.Iam using windows xp. help please,
  • 112 Answers
Delete all the USB ports in the device manager
Restart the computer to let XP install all the USB ports again.
Go to the first USB port and right click on it and go to properties. Then on the advance tab click on do not show warnings.
This should resolve the issue.
Is your PC a Dell by any chance?
If so there is a patch available to fix this also.
Please let me know how you get on.
Posted on Feb 26, 2008
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
I have a HP Deskjet F4400 All-in-one series. Under the icon for it, there is a box that says the printer is stopped. I can click on it and it will say "Start" but below there is a line that...
Hi rjrust958,
The easiest way to correct this problem is by uninstalling and reinstalling the software and driver of the unit. Please visit this link for the updated driver of HP Deskjet F4400 All-in-One Printer series. For additional information on how to uninstall/reinstall software and drivers please visit this link.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | HP Office Equipment & Supplies
Hp 3005X PAUSES BETWEEN PRINTING EACH PAGE. Data light is flashing and LED panel displays "processing"
Thank you for contacting FixYa for your printer inquiry.
We have had this problem before. If you install the driver from the hp site, the dot4 port is not installed properly. We had to clean all the dot4 entries out of the registry and install the printer from the cd.
Remove Dot 4 Port Steps:
  1. Click "Start" and then right-click "Computer." Click "Properties" on the pop-up menu.
  2. Click the "Device Manager" link on the left side of the new window.
  3. Double-click the "Ports" sub-heading in "Device Manger." Highlight a USB port that includes "DOT 4" as part of the device description. Right-click on the port devices name, and then click "Uninstall" on the pop-up menu.
  4. Uninstall other existing "DOT4" ports using the same method.
  5. Restart the computer and log in to Windows.
  6. Reinstall the driver software that came with your printer's CD.
The printer now functions properly in Windows.
USB problems are usually fixed by reinstalling the driver, just reboot the machine.
Better still hook the machine up to a LAN this is a network printer.
Hope this helps. Don't forget to rate this printer solution.
TF
Feb 28, 2011 | HP LaserJet P3005n Printer
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
Can't get my hp deskjet to print. all my usb ports work fine. can you help? there is an icon: safely remove hardware on the bottom right hand corner? ?? Not computer saavy.
Turn off the printer and uninstall all printer software. Use the install cd to reinstall the printer and switch on when told to connect printer by the install prog. You should be OK from there.
Dec 22, 2009 | HP D1660 InkJet Printer
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
USB Hubs won't install
Please install the usb hub power surge patch from www.dell.com/support
Aug 24, 2009 | Microsoft WINDOWS XP PROFESSIONAL SP3...
HP psc 1205 printer icon on system tray has exclamation mark. Have uninstalled and reinstalled using original software cd but still the same problem. Does this mean sofware error ? Should I uninstall again...
Better is to change USB port position. also ensure USB2.0 support is enabled in your BIOS. If some jobs waiting for print firs discard them and then install, but when you change port device installs automatically. Check cartridges for empty.
Aug 03, 2009 | Office Equipment & Supplies
No printer action from the computer when clicked on screen
Welcome to Fixya! Unplug all of the Cables from the Printer and let it set for 5 Min. Replug and Restart your PC and see what you can get.
Jan 05, 2009 | Office Equipment & Supplies
Printing problem
hi,
You need to reinstall the printer driver.
First check which operating system is used with your product? After that download the software from Download  Full Feature Software and Drivers.
How to Uninstall the printer Software :-
Follow the steps below to remove the hp LaserJet 1020 series software from the computer:
  1. Disconnect the USB cable from the computer.
  2. For the Windows Desktop, click Start , click Programs or All Programs , and then clickhp LaserJet xxxx series .
  3. Click Uninstall hp LaserJet xxxx series .
  4. Follow the messages on the screen to remove the software.
  5. Reboot the computer when instructed.
OR
2. For the Windows Desktop, click Start , click Crontrol panel, select add\remove(XP) or program future (VISTA).
 After restart install the printer driver and follow the screen instructed.
Sep 02, 2008 | HP LaserJet 1022 Printer
HP PSC 1210 All-In-One InkJet Printer Logo
67 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
