Question about OKI C5200n Laser Printer
SERVICE CALL 150:FATAL ERROR
MACHINE CONTINUOUSLY COMES UP SERVICE CALL 150:FATAL ERROR. I KNOW THAT THIS IS A YELLOW DRUM FUSE PROBLEM AND HAVE REPLACED THE DRUM BUT THE ERROR PERSISTS. I HAVE ALSO CLEANED ALL TONER SENSORS AND HAD PCB'S OFF AND CLEANED AND CHECKED ALL CONTACTS.
DO YOU HAVE ANY SUGGESTIONS?
    Problem Solver:
  • 5 Answers
Replace Toner and Drum clean everything and it should fix ur issue
Posted on Mar 25, 2008
Ricoh sp 210su service call sc559 problem
Code
SC559
Description
Fusing Unit Third Jam Error (Fatal Error)
Causes
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
Remedy
• After this error has occurred three times, the machine will shut down automatically and cannot be re-started until the machine has been serviced by a service technician. • Check the paper transport path for any physical obstructions (paper scraps, etc.) • Make sure the fusing unit has been installed correctly • After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
Apr 10, 2018 | Office Equipment & Supplies
HOW TO RESOLVE C8 ERROR IN RICOH SP 111 PRINTER
Ricoh SP 111 with C8 Error:
The C8 is a fuser error. As a safety feature, the machine will be disabled (to prevent fire and what not.. )
The service manual says that SC542 is caused by a too low fuser temperature, after 5 readings.
Since the hot roller was 5°C below the reload
(operating) temperature the fusing thermistor is deformed or out of position or full of gunk (toner residue). Or there may be a piece of paper between the sensor and the hot roller.
The fusing lamp harness can also bee loose, broken or defective.
The fusing unit can be defective
Executing Fuser SC Reset
1. After correcting the problem, open Smart Organizing Monitor.
2. Enter the service mode to display the Service Mode screen.
3. On the Service Mode screen, click [Fuser SC Reset]. This releases the fatal fusing error
which locks the machine.
4. Select "On" for Fuser SC Detect. This setting shuts down the machine if three successive
paper jams occur in the fusing unit.
Jul 27, 2017 | Ricoh Office Equipment & Supplies
Sir ricoh printer is not working in red light and display in c8 whats problem now tell me
Fusing Reload Temperature Error (Fatal Error)
There is a problem with the fuser section p/n M1014002 -Carl
IF THI IS A SP200
Apr 26, 2016 | Ricoh Office Equipment & Supplies
What does code DY means and how can I fix it
DY THE DRUM CARTRIDGE PRINT COUNTER (YELLOW) REACHES 60,000 SHEETS OR THE ACCUMULATED NUMBER OF ROTATIONS OF THE DRUM (YELLOW) REACHES 715K
If your machine is displaying one of these codes let your service provider know. The codes indicates that the respective drum cartridge has reached it's maintenance or replacement interval. The machine will continue to print normally but you may experience copy quality problems on your printed pages. When the service has been performed the service provider will reset the counter and the code will stop being displayed. In some cases, the machine may be set to stop printing when this code is displayed.
Oct 16, 2014 | Sharp MX-2700N Color Copier
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Model sp200s. What does c8 error indicate?
Apr 20, 2014 | Ricoh Office Equipment & Supplies
Show my printer on display C8 on Ricoh SP 100Su
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | OKI C5150n Led Printer
OKI C5200n Laser Printer Logo
762 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
