Question about Samsung HLN467W 46" Rear Projection HDTV
No Action from a HLN467W
Had an odd problem with my 4-5 year old Sam DLP. Last night the TV was on but wouldn't turn off either by the remote or power switch. The TV was completely unresponsive to any actions (volume level , channels, video mode, etc. Had to unplug the unit waited 15 mins and wouldn't turn on.
Plugged everything back in and the TV turned right on with no issues. Could this be a board problem and if so any idea on $$$? Think it's worth getting fixed?
Any help or ideas are appreciated Thank you
  • salda01 Feb 29, 2008
    Hasn't happened again since I unplugged it for the night and plugged it back in. Also, I have found that I have over 8600 hrs. on my still original bulb.
    President:
  • 4,402 Answers
I would wait to see if it happens again.
Posted on Feb 26, 2008
No power
replace the power supply board inside tv
Jan 30, 2013 | Emerson Televison & Video
Good morning Sam. Last night while watching TV the
Hello Andrew, Could I get you to please post the model number and make of the set. I will be better able to assist you.
Dec 03, 2011 | Samsung 56" Slim-Depth LED DLP HDTV
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with PartStore.com (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Thanks.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
My Samsung 60 inch DLP TV turns its self off several times an hour. Eventually is stays on. What's the problem?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.Have a bless one!
Apr 20, 2010 | Samsung Televison & Video
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Samsung TV about 4 years old, the tv turned off by itself last night and for whatever reason will not turn back on. When we use the remote the middle green light comes on in the middle as well when we use...
have u repleace the lamp yet , if not repleace, 4 years old would be a lot of hours the lamp may look intact but after severals hours tv start to go off
May 03, 2008 | Televison & Video
Sound problem
unplug it for a day. try again... the microprocessor is confused,
also check the button on the volume up and remote too make sure its not stuck down.
Dec 07, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLN467W 46" Rear Projection HDTV Logo
Henry  Thomas
Henry Thomas
