Not reading disc
Sumsang dvd player doesn't read the disc. I have changed the laser, but steal not reading.
  • gutsy69 Mar 25, 2008
    have cleaned the lens, sometimes it reads the disc, sometimes not! Lately it does not work at all!
  • Yvonne Orsini May 22, 2008
    I put the disc on the tray but it says there is no disc inside
I have clean the lenses already
Posted on May 22, 2008
    President:
  • 4,402 Answers
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Posted on Feb 26, 2008
Sony dvd player doesn't read disc says no disc when loaded
This would indicate the laser pickup assembly is the problem, try a DVD cleaning kit and follow instructions, if no change, far cheaper to replace the stereo.
Mar 17, 2012 | Televison & Video
Technika combi unit dvd player wont read discs anymore
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Jan 12, 2012 | Televison & Video
DVD player purchased 8/4/10 will not read disc. Model SD7300. Have used the cleaner disc.
Regards.
Apr 14, 2011 | Toshiba Televison & Video
It will read CD disk but will not read DVD disk have tried several different ones
Good luck.
Apr 14, 2011 | Phoenix Gold Phoenix Digital (PD-2122T)...
The Disc begins to be "read" and then stops suddenly, and restarts "reading" the disc until an error sign occurs on the screen
how long have you been using the player. There is every tendency that the lens (laser) of your player is weak and that's why it cannot read or play discs.
The lens (laser) is what makes the player reads discs, and if the lens is weak/dirty, there is no way it can read or play disc.
Get a lens cleaner and use it to clean the lens, if that does not solve the problem, then its means, the lens needs to be changed completely.
Good luck.
Apr 17, 2010 | Cyberhome CH-LDV 700B Portable DVD Player
We have used a laser cleaner, but it steal read no disc. it would play the laser cleaner though???
Forgive me if you know this already.
you need to eliminate whether the disc has been finalised before coming to you from another dvd player.
Check your dvd has the correct code,and that disc and dvd are correctly matched .
Look in the front of your manual and it will tell you alist of what the dvd can or can`t play.
All that sorted.Now try this ,I think there might be condensation in the dvd unit.
Take any dvd`s out if you can,but don`t worry if not.
Take the unit into a warm room, plug in to the mains and leave for 2-3hours.
Hope i`ve helped.
Dec 04, 2009 | TruTech LMD-5702RT Portable DVD Player
Cyberhome 1010A won't read disc
Clean the laser with a q tip and rubbing alcohol. That usually works with lasers that don't read. If this doesn't work ( be sure to let the alcohol dry and don't leave streaks) then I would either assume the laser isn't getting enough power or the laser is actually burned out.
Nov 01, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
