Whirlpool washer mashine # lcr7244hq1
My mother has whirlpool washer mashine # lcr7244hq1
stoped working complitly
looks like electrical problem
no lights showing lighting on the front panel
are there any fuses ?
  • danifour9 Oct 30, 2008
    appears to have no power, can't find fuses?
  • 6fungrandkid Nov 20, 2008
    Washer worked 2 days ago now it is completely not working is there a condensation switch
  • 156 Answers
No fuses bad control board
Posted on Feb 27, 2008
Hello, I have WHIRLPOOL washing mashine model AWE 2214. Yesterday during squeezing, the masine stoped without noise, no indication buttons.I cheked everything, but the mashine no start. Please, help me!...
Go to www.washingmachine-manual.com/whirlpool-awe-2214.html for the handbook. Make a cup of coffee and have a read up. If that fails to help then its an engineer I'm afraid.
If you have a good diy friend have them check the belt drive if it has one? Be careful of electricity and water, they don't mix.
Jul 21, 2014 | Whirlpool Washing Machines
My whirlpool duet "controll locked" lite is on and
This is also like Child Lock - It is usually indicated on the Facial Panel itself. Look for a small child's face, usually with a lock picture near it, it will indicate with arrows which 2 buttons to press. You hold these two buttons in for approx. 4 - 7 seconds. Do this while the machine is on though.
Hope it helps :-) - J.Q
Feb 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a hot point washin mashine that does not finish a wash and stopes half way through then lights at front of mashine start flashin
Had this with mine. Cleaned the filter (as decribed elsewhere on this site). Also cleaned the component fto which the drain hose attaches - guess this is the pump. Just unclip the drain hose and the hose going into this pump, and check there is nothing obstructing the pump. The clips are a bit of a fiddle, you might want 2 jubilee clips to replace them. Then ran a "maintenance wash" as per manual (ie a hot wash, no clothes, no detergent). Seems OK now
Nov 02, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool washer won't work, F02 light is on.
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jul 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not fill up with water before starting, it takes about 3-4 times brfore unit will run with full amount of water. loads take forever.
dish washers have a fill valve. the water supply line most likly has a net like filter that is stoped up with trash. Or fill valve is bad.
same thing happens to washing mashines. when they start filling up very slow you will TURN OFF water supply and diconect hose, look inside and there is the problem.
May 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
After mashine is in the middle of the cycle it
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. I believe you may have a bad lid switch. I suggest you go to www.acmehowto.com where they have an excellent video on directdrive washers. If you need additional help you could try www.applianceaid.com where they have very good trouble shooting and repair information on washers as well as other appliances. You can search for the meaning of the error code on the site. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My washing mashin shows F35; First shows sud
Check the drain line for kinks or obstructions first. Then check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check for anything clogging the pump and inspect the pump impeller for broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully, it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
489 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
