Question about Lexmark Wheelwriter 1500 Typewriter
Squeaking I'm using a Wheelwriter 1500, and it has started squeaking. Types okay, but making squeaking noise. Unrelated is that the correction funtion doesn't work. I've replaced the correction tape, but still doesn't work. Thanks!
  • Lexmark Master
  • 3,594 Answers
There are many things that will cause squeeking. First does it make noise when you tab or return if so open the cover and see if it goes away if so the red indicator may be rubbing on the margin scale, bend it back a bit. If it only squeeks when typing try a little WD40 on the motor that drives the print wheel the back bearing is a little hard to grt at.
Not correcting. Be sure you have a correctable ribbon on it(yellow og orange knob)
Hope this helps
DickyO
Posted on Feb 27, 2008
Heavy duty 20 lb..starting to make squeaking noises during agitation only
The bearings in the agitator are worn out and need replacing.
Jun 19, 2018 | Washing Machines
Dryer slow to start squeaks
The drum is belt driven, there is a belt tensioner on it too. You need to replace the belt.
Feb 25, 2015 | Kenmore Elite HE4 Electric Dryer
Mazda protege makes a squeaking noise when I start driving?
If your Mazda Tribute's engine has a rumbling noise when you start it, this is most likely from the drive belt. You will need to replace it.
May 30, 2013 | Mazda Protege Cars & Trucks
Brother 1034d squeaking
but you can check with the place you bought it from & tell them it's squeaking alot, & see if it needs to be oiled, or if they want you
to bring it back to them to be checked
Aug 09, 2012 | Brother 1034D Mechanical Sewing Machine
2010 electra glide ultra classic, squeaking noise from primary side only when riding. Could clutch or, belt be the problem. Clutch engages smoothly with no acceleration problems. Especially noticeable on...
You need to determine whether the squeaking is being made by the engine, the primary, the drive, or the frame. While riding, pull in the clutch, does the squeaking stop or change in any manner? Is the noise there when the engine is running but standing still? Pull the clutch lever in and release, does the squeak change or stop.
If I had to say what I think it is, I'd say it's probably the rear drive belt is not tracking correctly due to the alignment of the rear wheel. Look at the rear wheel adjusters. They should be exactly the same on either side of the swingarm. Also, the belt must be tight. If not, a loose belt will make a squeaking noise.
Good Luck
Steve
Dec 26, 2010 | Harley Davidson FLHTCUI Electra Glide...
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Engine Sqeak
a squeaking belt can be caused by wrong tension [belt slips] if belt looks polished then thats whats happenedif it has any cracks or polish marks replace it!
Jul 20, 2009 | 2000 Jeep Cherokee
Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Admiral Washing Machine Makes Squeaking Noise
THE BRAKE IS VERY FAMOUS FOR THAT NOISE NOT INSPECT THE PUMP ,, CAN BE GRINDING ON BOTTOM BASE OF WASHER ,, BEARING POPPED OUT
Nov 22, 2008 | Washing Machines
Compressor
You may have a problem in the evaporator fan . Defrost fridge for 24 hours and start up. Problem should go away for some time. For a long term solution you need to check if defrost cycle is funtioning well if not suspect the timer or the heater.
Sep 25, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Lexmark Wheelwriter 1500 Typewriter Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
