Question about Belkin (F5D7230-4) Router (587009)
Cant connect to the internet
Set up was working fine. switched my pc on one day and couldn't connect to the Internet, disconnected my router and could access the Internet. Checked all leads, switched off at mains, and powered up each in order. but to no avail.
Where do I go from here ?
  • 1 more comment
  • dockerdooley Feb 26, 2008
    thanks for that I'll give it a try
    Hi I'm on cable broadband, (virgin media) using a modem supplied by them, cant find any make on the modem.
  • robert samples May 11, 2010
    what kind of modem do you have are you on phone or broadband
    President:
  • 1,314 Answers
I have problems like this most of the time you have to renew your ip address you un plug power to your modem and router them count to 30 plug your modem back to power when all the lights come back on then plug power to your router and that renews your ip address i have to do this one or two times a month or when they up dater my modem
Posted on Feb 27, 2008
  • robert samples Feb 27, 2008
    ps some modems have a tiny button on back of them for this purpose you take an ink pin after un plugging your router and push it for ten seconds the rest is the same
  • 813 Answers
Ur connted with ur route by wifi or lan cable can u conuger the router befor join the internet
open the web page in the address bar type 192.168.1.1
then after loing screen come then put usr name is admin & pass: admin then press enter the after confuger your internet connation
just go in a in roter set user name & password of internet
Posted on Feb 26, 2008
IPSec Disconnected oftenly and cant login into Router
Sounds like a factory reset on the router will fix it and start new and everything should work again.
Sep 06, 2017 | Linksys RV042 VPN Router
Unable to connect to internet
Is the router proper connected to the modem?
Apr 20, 2010 | NetGear DG834G 802.11G Wireless ADSL...
Every time I connect router I lose internet connectivity - cable When I disconnect router, Internet is fine COmcast Cable blames router ; Cisco blames Comcast - cant get any where with either support team...
If your computer is able to go online through the
modem, that means the modem is working fine.
This router WRT160N hs firmware issues.
Try to upgrade the firmware of the router.
Is there any computer connected to the router with
the cable.
If not then you will need to connect the computer
to the router.
Download the firmware of the router from the
manufacturer's website.
enter the model number. select proper version
number and download the firmware of the router.
Once you download the firmware, you will need to
open the router set up and upgrade the firmware of
the router.
After upgrading the firmware, it is recommended
that you reset and reconfigure the router.
Click Here for more information about router and
networking
Feb 27, 2010 | Linksys WRT160N Wireless Router
I am wanting to run my (currently wired) laptop to be wireless (have bought a USB adaptor to do this), but also keep my main PC wired. I clearly need the internet on my PC to set up my DLink G ADSL2+. I...
You will need a wireless router with a built in switch. Most of them these days will have a built in switch. Here is a picture detailing what I am talking about.
You're internet connection goes into the ADSL port. Now, it will be broadcast WIRELESSLY through the antenna to your laptop. With this example, you could connect 4 more WIRED computers through the LAN ports. The built in switch is the division of the connection into the separate LAN ports.
I trust that this will help you greatly and look forward to your response!
Feb 26, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Can ping but cant connect to the internet
you may have to go to your routers ip address and see if you cant configure it to work or maybe your router can only support a certain number of wireless devices.
May 06, 2009 | ASUS Eee Pc 1000Ha 160G Netbook
No internet connection
Check your network settings and make sure your system is set to wired connection not wireless
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
Problem with a linksys ethernet cable router
The router may need to be reconfigure since you lost the internet connection , If you still have the setup CD you can just run it again or better call Linksys Tech support so they can walk you through with the process the number is 800-3267114 you can call them any time of the day..
Hope that helps.......
Sep 03, 2008 | Linksys WRT54GX4 WIRELESS 802.11G...
Internet Connects but disconnects suddenly
Who is your ISP?
It seems you are experiencing intermittent connection. Bypass the router and check if the same problem exist when connected directly to the modem. If the internet works fine with the modem.then you have to configure the router correctly.
Aug 14, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Belkin (F5D7230-4) Router (587009) Logo
55 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
